Question IMG Tag problem after upgrade to Kunena 1.5.5 PROPER
17 years 1 month ago #27167
by jerry
IMG Tag problem after upgrade to Kunena 1.5.5 PROPER was created by jerry
Just back from my holiday. I am seeing inproper fix for this issue. Actually in Kunena 1.5.5 devs tried to check file extension. Both modifications from users are wrong as they disable this check.
Proper solution is:
/components/com_kunena/lib/kunena.parser.php lines: 345-348
before:
after:
HaND, Jerry
Proper solution is:
before:
$file_ext = explode(',', $params->get('upload_extensions'));
preg_match('/\.([\w\d]+)$/', $between, $matches);
if (!in_array(strtolower($matches[1]), $file_ext)) break;
after:
HaND, Jerry
17 years 1 month ago #27174
by xillibit
Replied by xillibit on topic Re:IMG Tag problem after upgrade to Kunena 1.5.5 PROPER
Thanks for sharing this, I will transmit this to the DEVs.
- mjanzen128
- Junior Member
- Thank you received: 1
17 years 1 month ago #27223
by mjanzen128
Replied by mjanzen128 on topic Re: IMG Tag problem after upgrade to Kunena 1.5.5 PROPER
Oh, thanks for the info. I was wondering myself why IMG tags werent working on 1.5.5. Thanks a ton!
17 years 1 month ago #27250
by deso
Replied by deso on topic Re:IMG Tag problem after upgrade to Kunena 1.5.5 PROPER
Thanks for sharing, I was about to drop myself dead after seeing all the pictures gone in my board.
17 years 1 month ago #27334
by Matias
Replied by Matias on topic Re: IMG Tag problem after upgrade to Kunena 1.5.5 PROPER
Thanks Jerry for your fix.
BTW: Also line containing $matches = null; should go outside of that if clause (fixes a notice).
Sorry about the new bug -- we had bad security issues with existing exploits and we had to fix those as soon as possible. We didn't have enough time to test them well enough..
New release which fixes the new regression bugs will come in few days.
17 years 1 month ago #27381
by kmilos
Replied by kmilos on topic Re: IMG Tag problem after upgrade to Kunena 1.5.5 PROPER
Just out of curiosity (not a PHP coder): how come this code needs to go outside that if block, isn't that if block going to be executed every time since $file_ext is being initialized to null just above?
