Question IMG Tag problem after upgrade to Kunena 1.5.5 PROPER
If someone has better solution to this problem, I would like to hear from it.
- Lovegunner
Parse error: syntax error, unexpected '&', expecting T_VARIABLE in /home/bootleg/public_html/components/com_kunena/lib/kunena.parser.php on line 340
Are-you sure that you haven't insered others caracters with the code ? Can I see your code into the lines 335 and 345 ?Great..tried it and now i've lost my site... this is what i see...
- Crazyhorse
this is my code from line 335 up to 348 hope it will help.
$tag_new = "<a href='".$tempstr."' rel=\"nofollow\" target=\"_blank\">".$between.'</a>';
return TAGPARSER_RET_REPLACED;
break;
case 'img':
if($between) {
static $file_ext = null;
$matches = null;
if (empty($file_ext)) {
$params = &JComponentHelper:: getParams( 'com_media' );
$file_ext = explode(',', $params- >get('upload_extensions'));
preg_match('/\.([\w\d]+)$/', $between, $matches);
if (!in_array(strtolower($matches[1]), $file_ext)) break;
i copied the code Matias gave and all i got was the message Lovegunner also had.
hope this will help out solving the prob.
greetz Crazyhorse
EDIT: have been looking for more about this and in one way or another my file rights were set to not writable. so set the rights back to writable and all is working
nxt time will look on thi first lol :blush: :blush: :blush: :blush:
- Crazyhorse
any ideas on how to fix and why this now happend? checked my settings if writable and yes they are so i would really appreciate a fix if possible or any ideas on when the 1.6 is to go live.
anyway thnx for all the work you guys do, will keep my patience but do hope to see a fix or update about this.
greetz Crazyhorse
