Question Is it native or what?
17 years 4 months ago #22942 by gwmbox
Replied by gwmbox on topic Re:Is it native or what?
I have now also tried disabling every module and also turning SEF off - I only use the Joomla Sef.
Anyone able to have look for me - PM me and I will provide login to my DEV site for you to have a looksie :)
17 years 4 months ago #23036 by Matias
Replied by Matias on topic Re:Is it native or what?
I have a python script that finds most legacy code. Want to test it? Works great if you have Linux server and ssh access to it.
17 years 4 months ago #23099 by gwmbox
No SSH access :(
This is really bugging me - is anyone able to take a look or suggest anything else for me to try please?
Cheers
17 years 4 months ago - 17 years 4 months ago #23100 by sozzled
This is what I would do - it's not 100% bullet-proof, but it might provide you with some clues:
Go to Extensions » Install / Uninstall
You will see that 6 sub-functions you can choose from:
  • Install
  • Components
  • Modules
  • Plugins
  • Languages
  • Templates
Click, one by one, each of the items I've bolded above. Browse the listed items and look for any items that have a red X in the compatibility column. For example, see the following image (the red X is shown against the ObjectClarity Kunena Discussbot plugin):
If you find any items like these, disable them. See if that makes a difference. :)
Last edit: 17 years 4 months ago by sozzled.
17 years 4 months ago #23138 by gwmbox
Yes done that - they all have a green tick....
Any other suggestions....
17 years 4 months ago #23195 by sozzled
I think some more information is needed.
* Joomla version:
* Kunena version: 1.5.3
* mysql server version:
* php version:
* php max_execution_time:
* php memory_limit:
* safe_mode:
* Joomla template:
* Kunena template:
