Question Is it native or what?
17 years 4 months ago #23404 by gwmbox
sozzled wrote:
I think some more information is needed.
* Joomla version:
* Kunena version: 1.5.3
* mysql server version:
* php version:
* php max_execution_time:
* php memory_limit:
* safe_mode:
* Joomla template:
* Kunena template:
Ok info as requested
Joomla 1.5.12
Kunena 1.5.4
System Info:
PHP Built on: Linux SERVERNAME REMOVED 2.6.9-023stab033.9-enterprise #1 SMP Tue Dec 5 14:40:57 MSK 2006 i686
Database Version: 5.0.67-community
Database Collation: utf8_general_ci
PHP Version: 5.2.4
Web Server: Apache/1.3.41 (Unix) PHP/5.2.4 mod_fastcgi/2.4.2 mod_perl/1.30 mod_jk/1.2.25 mod_log_bytes/1.2 mod_bwlimited/1.4 FrontPage/5.0.2.2635 mod_ssl/2.8.31 OpenSSL/0.9.7a
Web Server to PHP interface: apache
Joomla! Version: Joomla! 1.5.12 Stable [ Wojmamni Ama Woi ] 01-July-2009 02:00 GMT
User Agent: Mozilla/5.0 (Windows; U; Windows NT 6.1; en-GB; rv:1.9.1) Gecko/20090624 Firefox/3.5 GTB5 (.NET CLR 3.5.30729)
PHP Settings
Safe Mode: Off
Open basedir: /home/USERNAME/:/usr/lib/php:/usr/local/lib/php:/tmp
Display Errors: On
Short Open Tags: On
File Uploads: On
Magic Quotes: On
Register Globals: On
Output Buffering: Off
Session Save Path: /tmp
Session Auto Start: 0
XML Enabled: Yes
Zlib Enabled: Yes
Disabled Functions: None
Mbstring Enabled: Yes
Iconv Available: Yes
WYSIWYG Editor: Editor - No Editor
max_execution_time: 30
memory_limit: 64M
safe_mode: Off
safe_mode_exec_dir: no value
safe_mode_gid: Off
safe_mode_include_dir: no value
Joomla Template: changed back to JA Purity to see if that helped but no help
Kunena Template: changed back to default_ex
Any more info needed?
17 years 4 months ago #23406 by Lintzy
Replied by Lintzy on topic Re:Is it native or what?
gwmbox wrote:
Anyone able to have look for me - PM me and I will provide login to my DEV site for you to have a looksie :)
You can send me a PM, I could look if I get it work.
17 years 4 months ago #23411 by Lintzy
I found the issue, it is the integration with Community Builder. When I set the profile from CB to Kunena it works in native mode.
Now I am looking, if I can fix that.
17 years 4 months ago #23413 by gwmbox
Replied by gwmbox on topic Re:Is it native or what?
Wonderful news :)
And thanks for your help, here's hoping the CB issue can be rersolved :)
I'll make a donation to the Kunena Dev shortly :)
17 years 4 months ago - 17 years 4 months ago #23416 by Lintzy
You have so much plugins installed in CB, that it seems to be to hard to figure it out.
I have read here, which things causes this issue:
docs.kunena.com/index.php/CB_integration...in_Community_Builder .
Point 3,4,5 are ok
Point 2: I have built a new Menu item for Profile user, but this not fix it.
So please read here and go step for step through the CB Installation, like it @quila has written:
www.kunena.com/forum/12-community-builde...it=10&start=20#21107
I hope this will fix it.
PS: Go to Kunena Configuration / Integration and set Profile settings / Profile to Kunena, than disable legacy plugin and you will see, that it works in native mode.
You can delete my account ;-)
Last edit: 17 years 4 months ago by Lintzy.
17 years 4 months ago #23417 by gwmbox
Thanks very much for your help with this. I will do a disable of all CB plug-ins and do a process of elimination until I find the conflicting plugin and see how it goes.
At least now I have it narrowed down to what is causing it.
Cheers
