Question Is it native or what?
17 years 5 months ago - 17 years 5 months ago #21405 by WinuxFF
For the very start, hello everyone :)
I have a just a small question for community
Is K1.5.3 really Native?
Kunena was the LAST legacy component on my site and i upgraded from 1.0.10 to 1.5.3
It works really smooth but only with Legacy plugin ON - it should work with that plugin OFF or im missing something here?
I got "no direct acess allowed" error when its off
Thanks in advance for your inputs
Last edit: 17 years 5 months ago by WinuxFF.
17 years 5 months ago #21406 by jerry
Replied by jerry on topic Re:Is it native or what?
Yes it's really native, you can upgrade to Kunena 1.5.3 and disable legacy plugin.
Try to disable other modules/plugins on your site, just to be sure, it doesn't affect. Then enable one-by-one and you will see, when it happens.
17 years 5 months ago #21408 by WinuxFF
Replied by WinuxFF on topic Re:Is it native or what?
Except kunena, i had nothing else in legacy mode. All mine components, plugins and modules are native but ill try your suggestion right now
17 years 5 months ago #21431 by jerry
Actually the sign of nativeness is nothing. There could be lost function from legacy.
And one more place, where could be problem.
Template. I found some templates (native Joomla 1.5 was stated from the author) that used legacy code. So try also revert to default Joomla 1.5 site template...
17 years 5 months ago #21450 by WinuxFF
Actually problem was gone when i switched kunena templates
Default_ex just refuse to cooperate :) but im ok with that as long as default works
Thnx for bringing up the template thingy
17 years 5 months ago - 17 years 5 months ago #21451 by jerry
Nope, default_ex should work. I was talking about Joomla templates, not Kunena templates. Do you have patched default_ex? If not, try to reupload only default_ex folder. What error it gives if you switch to default_ex template from Kunena 1.5.3 package? What plugins do you have installed on your Joomla?
Last edit: 17 years 5 months ago by jerry.
