Kunena 7.0.7 Released
Sticky IPB, Punbb, Phpbb3, SMF2 to Kunena solved
16 years 3 months ago #43610 by Collector
Collector wrote:
After running the script I received a message on successful completion. The migration was successful, but CONTROL PANEL lost a few points as the site configuration templates. Do you have any ideas?
I solved the problem just creating a new record for the super administrator :P
16 years 3 months ago - 16 years 3 months ago #44441 by Acidream
Hello!
Can some one wrote simple FAQ to this migrator?!
I have installed phpbb3 in the url/forum/ and joomla 1.5.14 in root folder.
Name of joomladb is joom5 and name of phpbbdb is phpbb5.
I installed the Universal Password Integration - Forum Migrations
I uploaded the Migration folder to the Joomla folder and used the address url/migrator/index.php
What I must write in MYSQL User and MYSQL Pass forms? Or I need to import all data from phpbbdb to joomladb? Whatever I tried both ways and when I press Load Databases! I saw only "Fallo cargando la URL" Say please what I do wrong?
Last edit: 16 years 3 months ago by Acidream.
16 years 3 months ago - 16 years 3 months ago #44459 by forum-migrations
sorry but i dont have time for write FAQs.
You need 1 mysql user with access to your phpbb database and Joomla database(is common on some servers use user cpanel data for mysql access).
Example: when installing joomla you have to write your database, mysql user and pass, use same user if have access to phpbb too.
Regards
Last edit: 16 years 3 months ago by forum-migrations.
16 years 3 months ago #44528 by Randal
Hello @forum-migrations I've got bad news. Did you know that your site is not available for me (and probably for some others too)? I'm browsing from Poland. Did you blocked some IPs or regions? Now I see by hidemyass.com that site is normally working but not for me. I've got system SERVER NOT FOUND message. Someone have this problem too?
16 years 3 months ago - 16 years 3 months ago #44992 by S.Nieves
For some reason I can't access the
I created a new folder in the root directory where joomla is and called it migrator.
I get an error, not the conversion. Any ideas?
SOLVED! I successfully converted over using the method posted in the kunena docs!! :D
Last edit: 16 years 3 months ago by S.Nieves.
16 years 2 months ago #46679 by Jed11
I've got a very small database with SMF 2.0 RC3 (338 Posts in 19 Topics by 8 Members).
I'm getting unresolved querry errors of "'re". Your script does effectively erase all users of the joomla database even if it errors out and doesn't import or migrate the users of the smf database.
I'm not versed enough with PhPAdmin or mysql to know how to resolve these queries without some instructions and I'm not going to chance another failed migration have have my existing users wiped out.
Time to create page: 0.356 seconds
