Kunena 7.0.7 Released
Sticky IPB, Punbb, Phpbb3, SMF2 to Kunena solved
16 years 3 months ago #42955 by DTP2
Just tried to convert my phpBB3 forum to Kunena.
Installed a fresh Joomla (1.5.15) and the latest Kunena.
Installed the plugin universalpassfm.php.zip.
Opened the folder migrator7 in my browser and followed the steps.
Message says it finished succesfully, but there are no categories in Kunena at all.
Even worse, my administrator login isn't recognized anymore, so I cannot access my Joomla backend.
Please tell me what went wrong.
16 years 3 months ago - 16 years 3 months ago #42970 by forum-migrations
Hi, remember that the script is a test, not a project.
About that error, you can try with this:
(by a tester, i think that with large databases or sometimes the behaviour is unexpected)
test.php
Change line 141 with this: (or find something similar)
if(gettype($val)=="string") { $final[$key]=html2bbcode(addslashes(html_entity_decode(str_replace('\'', '`', $val))));}
Because this test use a plain text mode
Last edit: 16 years 3 months ago by forum-migrations.
16 years 3 months ago #43016 by DTP2
I must admid that I am not really able to read from your website what the meaning of this project is, but I thought I could give it a try in a test environment. And since this whas a test for me and the script says it is a beta I thought you might want to know about errors or problems occuring while or after the conversion.
Thank you for your reply.
16 years 3 months ago - 16 years 3 months ago #43042 by Collector
After running the script I received a message on successful completion. The migration was successful, but CONTROL PANEL lost a few points as the site configuration templates. Do you have any ideas?
SMF2=>KUNENA
:blush:
Last edit: 16 years 3 months ago by Collector.
16 years 3 months ago - 16 years 3 months ago #43166 by AntonioP
Hello !
I've have tested and i like it.. but i have few errors :
Migration State
Invalid query: You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '00-'01','1231971498','93.103.59.70','0','0','0','0','78','0','null','null','null' at line 1 Whole query: insert into hms_fb_messages (id,parent,thread,catid,name,userid,email,subject,time,ip,topic_emoticon,locked,hold,ordering,hits,moved,modified_by,modified_time,modified_reason) values ('63','0','63','35','Anonymous','62','[email protected]','Akustika v ibiza '00-'01','1231971498','93.103.59.70','0','0','0','0','78','0','null','null','null');
1.) then i checked on kuena forum.. Topic are showing but not the posts..
where i did go wrong..???
what i do :)
1.) i have silly webhoster so i've import database of phpbb forum tu my testjoomla database and then migrade.. ( why) because i use difrend usernames and passwords for my databases :( . this was the only way to even start migrate :)
can someone help me out ?
i really like more kuena then phpbb :woohoo:
one more error :
Migration State
Invalid query: Table 'antonioper_testphpbb.hms_fb_categories' doesn't exist Whole query: insert into hms_fb_categories (id,parent,name,cat_emoticon,locked,alert_admin,moderated,moderators,pub_access,pub_recurse,admin_access,admin_recurse,ordering,future2,published,checked_out,checked_out_time,review,hits,description,headerdesc,class_sfx,id_last_msg,numTopics,numPosts,time_last_msg) values ('20','116','LEON Mk1 LEON Mk2','0','0','0','0','null','0','0','0','0','20','0','1','0','0000-00-00 00:00:00','0','0','','','','5066','1','35','1246567261');
Last edit: 16 years 3 months ago by AntonioP.
16 years 3 months ago #43468 by renzo
I can't understand this topic. You write about a script converting to kunena but I do not see this script. Where is it?
Some user asks also if it is valid for SMF 1.1.xx. Me too repete the request.
Please advice any metod to convert form SMF 1.1.xx to Kunena.
Thank you
