- Thank you received: 3
Idea Display Error in both 1.0.8 and 1.0.9 plus additional in 1.0.9 (SOLVED)
- grumblemarc
- Elite Member
- Still making trouble
17 years 5 months ago #11437
by grumblemarc
Replied by grumblemarc on topic Re:Category Title Spacing in Categories View
Merged threads.
17 years 5 months ago #11438
by sapromo
Replied by sapromo on topic Re:Category Title Spacing in Categories View
- grumblemarc
- Elite Member
17 years 5 months ago #11440
by grumblemarc
If this does not happen in the Joomla default templates then it is your CURRENT Joomla template causing you the issues. YOU need to fix IT and not Kunena. Do not continue to hack the Kunena CSS because it will be broken if you turn around and switch Joomla templates later. Get FireBug and track it down.
17 years 5 months ago #11457
by sapromo
It is the Kunena template, see post from Lintzy further up... even the Kunena forum displays the categories wrong
- grumblemarc
- Elite Member
17 years 5 months ago #11458
by grumblemarc
On the default Joomla template it does this? I have not seen this. What Joomla template are you using?
17 years 5 months ago #11459
by sapromo
No, it does this on the default Kunena template, try viewing it in IE7. I use the default_ex template on Kunena and Jooma is Versatility 4
Time to create page: 0.221 seconds
