Idea Display Error in both 1.0.8 and 1.0.9 plus additional in 1.0.9 (SOLVED)
17 years 8 months ago - 17 years 7 months ago #9372 by sapromo
Hope this is the right place to ask.
In the categories view, any of them, if there is new posts the category title mixes up with category title.
See attached image.
URL: www.sapromo.com/saforums
Thank you in advance for any help or support.
Last edit: 17 years 7 months ago by sapromo.
17 years 8 months ago #9416 by Lintzy
I must see this bug live: a new post. Perhaps i could fix it, it is a CSS Problem only.
I have subscribed this thread, so i'll get an e-mail, if you'll answer here.
17 years 8 months ago - 17 years 8 months ago #9509 by Lintzy
I think, it is a standard problem of default_ex template, I could reproduce it. Open your kunena.forum.css from your template folder, it looks as default_ex
search the code above and add the red marked lines into the css, save and upload it.
#Kunena div.fb_thead-title a {
float:left;
font-weight:normal;
.fb_thead-moderators {
clear:left;
span.newchar {
color:#CC0000;
font-family:Tahoma,Verdana,Arial,Helvetica,sans-serif;
font-size:xx-small;
font-weight:bold;
margin-left:3px;
Last edit: 17 years 8 months ago by Lintzy.
17 years 7 months ago - 17 years 7 months ago #11431 by sapromo
I have attached two images,
The first show display error in Kunena 1.0.8,
when unread messages in category it appears green, so the the category title and description is overlapping... screenshot from this forum to show it is not a problem just on my website
The second, is after upgrade to Kunena 1.0.9, the MAIN PAGE wont process the HTML code anymore used in description field... it worked fine in 1.0.8 and works on sub categories just not on main.
Any and all help appreciated
THANK YOU!
17 years 7 months ago #11432 by sapromo
17 years 7 months ago #11434 by sapromo
Hi Lintzy,
For some reason I was not notified of replies... have posted the same issue twice now but have additonal issue on this website www.sapromo.com/saforums
The HTML is not being processed in category description... I am going to try fix using above solution for problem number 1, THANK YOU!
