Question " Errors while Installing 1.08
17 years 9 months ago #4056 by Matias
Replied by Matias on topic Re: Errors
It looks like because of the safe mode, installation has failed on timeout. Kunena cannot be installed in 30 seconds in most of the environments because of unzip in Joomla! 1.5 installer is way too slow.
This is Joomla issue, not Kunena. You may try to install Kunena forum from URL instead of uploading the file. It may work..
.. or you can manually change timeout to 300 seconds, install Kunena and turn the timeout back to the default value..
.. or you can contact to your hoster..
17 years 9 months ago #4060 by JerryLeeLewis
Replied by JerryLeeLewis on topic Re: Errors
i will try via URL and let you know
But this the First Component with that Problem and i have Components like Virtuemart on with no Problems
17 years 9 months ago #4064 by fxstein
Replied by fxstein on topic Re: Errors
Have you checked the Technical Requirements page?
docs.kunena.com/index.php/Technical_Requirements
Can you confirm, that you made these other changes to php. Somehow you need to get past the slow J1.5 installer. The install for Kunena will most certainly run longer than 30 sec - which is the default on many servers.
You can manually increase this to e.g. 300 sec, run the install and set it back to 30 sec.
Hope this helps!
fxstein
17 years 9 months ago #4075 by JerryLeeLewis
ok i checked my settings in 'PHP info
php max_execution_time >= 60
php memory_limit 40M
so i cannot Kunena 1.08 with that settings is this right ???????????????????????
17 years 9 months ago - 17 years 9 months ago #4091 by JerryLeeLewis
i installed now via tmp direction
didn work !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!11
Site down again
thats not fine i remember fireboard -- a lot of problems
Last edit: 17 years 9 months ago by JerryLeeLewis.
17 years 9 months ago #4118 by Lintzy
Did you read in German Childboard the tipp with Joomlabackup? With this solution, other user could install, notwithstanding timeout problem.
www.kunena.com/forum?func=view&catid=36&id=3374#3381
