Question " Errors while Installing 1.08
17 years 9 months ago #4409 by oMikR0n
same here :( thnx a lot mate
17 years 9 months ago - 17 years 9 months ago #4487 by batmonkey
Well, on goeth the saga...
After getting 1.0.8 to work fine, I went ahead and installed the new Object clarity discussbot. Guess what... same error:
Fatal error: Call to undefined function check_dberror() in /home/mysite/public_html/components/com_kunena/class.kunena.php on line 99
So can someone tell me what changed from 1.0.7 to 1.0.8 that keeps bringing up that error in the addons?
Cross posted on discussbot thread and @ Object Clarity .
Last edit: 17 years 9 months ago by batmonkey.
17 years 9 months ago #4507 by grumblemarc
Maybe the question should be what does ObjectClarity need to change to get it working again?
17 years 9 months ago #4520 by fxstein
Replied by fxstein on topic Re:
oMikR0n wrote:
i got the same error on joomla 1.5, php 4.4.7, mysql 4.1.22. I tried deleting directories after uninstall 1.0.7b but i got the same error!
Fatal error: Call to undefined function: check_dberror() in /home/mo509/public_html/perasa.gr/components/com_kunena/class.kunena.php on line 99
Hi your install did not complete based on the info you gave above. mysql 4.1 is depreciated and not supported. It is listed in the tech requirements
docs.kunena.com/index.php/Technical_Requirements
and the installer checks for that. It says very clearly in RED that the install has been aborted if you attempt to install it on mysql 4.x.
Please reconfirm that the install ended with everyhting GREEN and a success message. Otherwise you have a non working installation that you should remove.
Hope this helps!
fxstein
17 years 9 months ago #4521 by fxstein
JerryLeeLewis wrote:
than my Provider must be stupid
Lintzy its not fault
Please delete my Account here
Jerry,
We are all trying to help. Obviously there is something wrong in your particular case that we have not been able to guess.
I'd be happy to look into your problem in person if you could give me access to your system. I am pretty sure this is a rather simple to diagnose problem. It is just impossible to do that blindly. Based on you responses, it might not be the install at all and it might have worked from the beginning - it could be as simple as an old FB mambot or plugin that is causing this.
Again we are here to help if you choose so. I believe you saw that we responded swiftly and other members tried to step in and help as well.
Nobody is stupid and this is not the old FB.
Our sencere appologies - we want to help.
Have a great day!
fxstein
17 years 9 months ago - 17 years 9 months ago #4602 by PGLion
Replied by PGLion on topic Re:
Same problem here:
Fatal error: Call to undefined function check_dberror() in /home/server/domains/mysite/public_html/components/com_kunena/class.kunena.php on line 99
[K-DISCUSSBOT DEBUG: Discussbot called with row->id=18630. ] [K-DISCUSSBOT DEBUG: Article is not being displayed on the Front Page ] [K-DISCUSSBOT DEBUG: Searching for {mos_fb_discuss:#} tag in article text... Found one! ] [K-DISCUSSBOT DEBUG: Rendering the bot... ] [K-DISCUSSBOT DEBUG: Kunena Config loaded from the DB. ] [K-DISCUSSBOT DEBUG: Kunena Config(CKunenaConfig,DB): discussbot=[1] ] [K-DISCUSSBOT DEBUG: Kunena Config(CKunenaConfig,DB): joomlastyle=[0] ] [K-DISCUSSBOT DEBUG: Kunena Config(CKunenaConfig,DB): template=[default_ex] ] [K-DISCUSSBOT DEBUG: Kunena Config(CKunenaConfig,DB): board_ofset=[0] ] [K-DISCUSSBOT DEBUG: Found the FB threadId in the cross reference table(#__fb_discussbot). ] [K-DISCUSSBOT DEBUG: User is a moderator. ] [K-DISCUSSBOT DEBUG: Kunena Config(CKunenaConfig,DB): pubwrite=[0] ] [K-DISCUSSBOT DEBUG: User has permission to post in FB category 33. ] [K-DISCUSSBOT DEBUG: User is logged in. ] [K-DISCUSSBOT DEBUG: Article Id is 18630 ] [K-DISCUSSBOT DEBUG: Counted 1 actual post(s) in this thread #16508. ] [K-DISCUSSBOT DEBUG: Rendering Comments with 1 actual posts. ] [K-DISCUSSBOT DEBUG: Limiting rendered comments to 25 posts. ] [K-DISCUSSBOT DEBUG: Kunena Config(CKunenaConfig,DB): avatar_src=[cb] ] [K-DISCUSSBOT DEBUG: Showing Last posts in the thread in Ascending order. ] Fatal error: Call to undefined function check_dberror() in /home/thaipo01/domains/thaiportal.nl/public_html/components/com_kunena/class.kunena.php on line 99
Installation worked very well, discussbot doesn't work. Please help!
Last edit: 17 years 9 months ago by PGLion.
Time to create page: 0.168 seconds
