Question " Errors while Installing 1.08
17 years 9 months ago #4044 by JerryLeeLewis
After install in Backend
Warning: set_time_limit() [function.set-time-limit]: Cannot set time limit in safe mode in /xx/administrator/components/com_kunena/install/kunena.install.php on line 27
and in live Site
Call to undefined function check_dberror() in /xx/components/com_kunena/class.kunena.php on line 99
So Site wont work anymore :(
17 years 9 months ago #4046 by fxstein
As with Joomla you cannot run installs in php safe mode.
Please see this official Joomla help article:
docs.joomla.org/Why_shouldn't_you_use_PHP_safe_mode%3F
Make sure safe more is turned off , re-install and you should be ready to go.
Hope this helps!
fxstein
17 years 9 months ago #4048 by JerryLeeLewis
Replied by JerryLeeLewis on topic Re:
I never ever had any Problems with that Hoster and he is a 100% Joomla Hoster
see here www.fc-hosting.de/
17 years 9 months ago #4051 by fxstein
Replied by fxstein on topic Re:
Now the safe mode is only a warning. We use the php function to increase the timeout to not hit the white-screen problem.
It sounds like you install did not finish, our your site would be running normally. This is a missing php file.
Can you check?
fxstein
17 years 9 months ago #4054 by JerryLeeLewis
Sorry what should i check
17 years 9 months ago #4055 by fxstein
Aside from that warning - did the install complete? Did it say Done without showing any errors?
