Question Kunena 1.0.10 "505 Install Error" HELP!
17 years 5 months ago - 17 years 5 months ago #19860 by CaJuaL
AHHH With your second post, I believe you may have solved the problem.
The platform is Debian.
Would this be the issue? :( Alot of people use Linux though >.<
Last edit: 17 years 5 months ago by CaJuaL.
17 years 5 months ago #19861 by Lintzy
I believe not, because Debian is Linux. :(
17 years 5 months ago #19862 by CaJuaL
Replied by CaJuaL on topic Re:Kunena 1.0.10
LOL yeah... I just edited my last post which shared the thought!
17 years 5 months ago - 17 years 5 months ago #19863 by sozzled
Replied by sozzled on topic Re:Kunena 1.0.10
CaJuaL wrote:
1) Wouldn't it be best to install CB first or no?
2) Would I be able to install Kunena first and THEN CB?
3) If Kunena DOES work on a brand-new website, what steps do I take to "add the other bits I need".
  1. It probably doesn't matter what order you do them in. If you involve Community Builder in any way on a website where Kunena 1.0.10 is installed you have to use CB 1.2.1. If you already have CB 1.2.1 installed, you can only use K 1.0.10 (or a later version) with it.
  2. See my answer to Q1
  3. "Other bits" are installed as per normal - use the Joomla Installer. Kunena doesn't really need anything else to operate with. You could, conceivably, run your site without Community Builder. What "other bits" do you want to use? If you want a private messaging system, use uddeIM. If you want a discussbot, use ObjectClarity Discussbot. These are the only "other bits" that I am aware of that integrate nicely with Kunena (except for CB, of course).
Last edit: 17 years 5 months ago by sozzled.
17 years 5 months ago #19864 by CaJuaL
I'm attempting to install it on another server now, taking the suggestion.
I still have the problem on my main one though :(
17 years 5 months ago #19865 by Lintzy
Hm, could be something with file permissions, too ->
globalmoxie.com/help/faq/errors/internal-server-error.shtml
