Question Kunena 1.0.10 "505 Install Error" HELP!
Grasping a straws for a moment, there may be a permissions issue on your directories. Have you investigated that? If we don't ascertain that you can install any version of Kunena on any version of Joomla then it points to something most peculiar with your webhost's setup.
Well I have a CGI log of errors. Here are the last few. Not sure if this would help any.
PHP Warning: eregi() [<a href='function.eregi'>function.eregi</a>]: Unmatched \{ in /hermes/web06/b2268/moo.cajual/administrator/components/com_admin/tmpl/sysinfo_config.php on line 57
PHP Warning: Invalid argument supplied for foreach() in /hermes/web06/b2268/moo.cajual/administrator/modules/mod_submenu/mod_submenu.php on line 118
Here is the Perl info:
How Perl works at FatCow
FatCow's PowerPack allows you to write scripts using Perl. To ensure that your Perl scripts work smoothly, please refer to the following information before you get started:
Path to your Web directory: /home/users/web/b2268/moo.cajual
This is important, as most of your scripts will need to specify this location. For example, this is required if uploading files was a function that you'd like your Perl script to do.
Path to Perl: /usr/bin/perl
Note that FatCow's CGI servers automatically direct your scripts to this path. You do not need to change the "#!" line at the top of your scripts.
Version of Perl: 5.8.8
This is the version of Perl that FatCow runs on its servers. Newer versions may be installed as they become available.
Perl Modules installed: Full List
These are pre-made Perl components that you can reuse to make your scripts work. You can also write your own Perl modules.
Required filename extensions: .pl or .cgi
These are the extensions that your Perl files must have or they will not work. For example, they would be yourscript.cgi or yourscript.pl.
Recommended path: yourcompanyname.com/cgi-bin/yourscript.cgi
If you do not have a domain name, point to: yourusername.fatcow.com/cgi-bin/yourscript.cgi .
Note: FatCow recommends that you use your cgi-bin as the default folder for all your cgi scripts. We cannot guarantee that they will work outside of this folder.
If you need anymore information let me know. I'm not sure what "permissions" you are all talking about
See docs.kunena.com/index.php/Securing_Kunena and links therefrom.I'm not sure what "permissions" you are all talking about.
Perl may have an impact but it also could be a red herring. There's nothing in Joomla that allows you to configure the Perl path. Let's focus on whether you can install J! 1.5.10 and K 1.0.10 successfully ... because I know that works!
The errors referred to in your message ( #19873 ) would seem to suggest the cause of the fault lies within Joomla.
