Question Kunena 1.0.10 "505 Install Error" HELP!
17 years 5 months ago - 17 years 5 months ago #19854 by CaJuaL
Okay, after endless searching to find out any solution to this issue.. I have given up and registered to see if any of you guys could help me :)
My webhost meets all requirements, and I also enabled the legacy plugin. My php.ini is also suitable for the installation. Everytime I try and upload to install, I get a blank page with only the following lame error:
The server encountered an unexpected condition which prevented it from fulfilling the request.
The script had an error or it did not produce any output. If there was an error, you should be able to see it in the error log.
I also tried to install Kunena v1.5 but I also received the same error.
I have the following installed already:
- Joomla 1.5.11
- Community Builder 1.2
I am a newb to all of this, but I'm a quick learner. :) I've been able to solve every other problem I've encountered so far.... but now I'm stumped. :(
Help is greatly appreciated!
Last edit: 17 years 5 months ago by CaJuaL.
17 years 5 months ago - 17 years 5 months ago #19855 by sozzled
I don't know what might be causing your "505 Install Error" problem.
Were you using a previous version of Kunena before you attempted to install K 1.0.10?
If you want to use K 1.0.10 (and there's no good reason why you shouldn't) and you want to use Community Builder, you must upgrade to CB 1.2.1. Kunena will not work with CB 1.2. If you have any old version of Kunena (before K 1.0.10) installed, CB 1.2.1 will not work either!
I have not yet read confirmation that K 1.0.10 operates in a J! 1.5.11 environment. I can say that K 1.0.10 works in J! 1.5.10 (and J! 1.5.9). That's all I can tell you.
Last edit: 17 years 5 months ago by sozzled.
17 years 5 months ago #19856 by CaJuaL
I appreciated your willingness to help me sozzled :) (+karma)
However, no I've never used Kunena in my life. Heh... I'm new to everything... a whole new world I explored, in which I almost wished I hired someone for. :P
And please excuse my ignorance. Yes, I *am* using CB 1.2.1 already! Heh :blush:
I have no previous installation of Kunena.
Everything is fresh. I installed Joomla 1.5.11 then CB 1.2.1 then my attempt to install Kunena that follows, led me to here.
I double and triple checked all PHP and mySQL info and I meet all the requirements. And legacy is enabled. *sigh*
I also contacted my webhost... says they think it's an application problem, in which they do not provide support for. :(
But anyhow, your continued support is appreciated!
Any ideas?
17 years 5 months ago - 17 years 5 months ago #19857 by sozzled
Thank you for the increased Karma (I bet someone will reduce it soon enough!! :laugh:). I had planned to upgrade one of my Kunena websites to J! 1.5.11 today (if I get time to do it) just to see if it presents any problems with K 1.0.10.
In your case, may I make the following suggestion?
Create a brand-new website with J! 1.5.10. Don't add any other components to it, just leave it as a "vanilla-flavoured" site, and then try to install Kunena 1.0.10. If that doesn't work, please report your findings here. If it does work then you haven't really lost too much, have you? You can then add the other bits you need.
Installing Joomla, then Kunena, is less than half-an-hour's "work". I think the effort is probably worth it, don't you? :)
17 years 5 months ago #19858 by Lintzy
Perhaps this point can shed some light upon it:
If you google for the string "The script had an error or it did not produce any output" in most of answers you will find the word CGI.
Here is a short summary of some (not all) possible causes:
support.discusware.com/center/resources/errors/spno.html
Please ask your provider, if your webspace is on a windows-server.
A "script produced no output" error occurs on Windows servers when attempting to access a CGI script on a server that is not properly set up to handle CGI scripts
This could be ONE cause.
17 years 5 months ago #19859 by CaJuaL
lol definitely. I'll try that out right now.
Just a couple questions before I proceed:
1) Wouldn't it be best to install CB first or no?
2) Would I be able to install Kunena first and THEN CB?
3) If Kunena DOES work on a brand-new website, what steps do I take to "add the other bits I need". Frankly I would never know which bits I need :(
heh...
