Solved Preview does not work
11 years 4 months ago #166700 by sozzled
Replied by sozzled on topic Preview does not work
paxx wrote: Kyle (CB Team) is now rewriting this plugin and according to him everything will be tested before a release. ... I'll just have to skip the feature where GJ members could have their "own" forums depending on groups.
As I have written before in this forum, I don't know whether GroupJive will ever work satisfactorily with Kunena. It is possible for forum users to have their "own" categories (using standard Joomla ACL) but it's not quite as easy to do, I guess, if you want this done "automagically".
Also, I do not know if the Kunena team have much active involvement with the CB team these days. That's something you might ask Kyle about, too.
11 years 1 month ago #168868 by phredcg
Replied by phredcg on topic Preview does not work
I am afraid I have the same issue of Preview not working.
I have tried all the suggestions here. I have disabled all the plugins, and still no success. I have also tried different templates, including Joomla and Kunena templates, but that made no difference.
I am including the configuration here hoping for some assistance.
The forum is for registered users, but if someone can be of assistance if they have access please let me know.
Thanks you.
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 64M
Joomla default template details : design_control | author: Shape5.com | version: 1.0 | creationdate: Unknown
Kunena default template details : Blue Eagle | author: Kunena Team | version: 4.0.5 | creationdate: 2015-08-17
Kunena version detailed: Kunena 4.0.5 | 2015-08-17 [ Turnau ]
Third-party components: CommunityBuilder 2.0.11
Plugins: None
11 years 1 month ago #168869 by xillibit
Replied by xillibit on topic Preview does not work
If you have firefox, open firebug and select tab console, then open preview and check in the in firebug console if you have javascript issue ? If you have some errors, copy them here
11 years 1 month ago #168870 by phredcg
xillibit wrote: If you have firefox, open firebug and select tab console, then open preview and check in the in firebug console if you have javascript issue ? If you have some errors, copy them here
Yes, I did that, too. Checked in Firefox with Firebug and in Safari with Safari's debug console. No errors reported with either one.
Oh, and thanks for the prompt reply!
11 years 1 month ago #168873 by xillibit
In console you should see the URL of Ajax request, if it's red it means that an error has occured.
Can-you do a screenshot of console window ?
11 years 1 month ago #168881 by phredcg
Thank you again for your quick response!
I am including a screenshot of the console window as requested on a page where I tried to enter a new topic, showing both the page where you enter the information and the preview pane. As you can see, there are no errors indicated in the preview pain.
Thinking their might be a conflict, I have tried disabling a number of different extensions and trying again (not all), including completely disabling Community Builder. Nothing has worked thus far.
Thanks for your efforts.
Time to create page: 0.161 seconds
