Solved Preview does not work
11 years 3 weeks ago #169753 by phredcg
Replied by phredcg on topic Preview does not work
I wanted to jump in here again. I am having this same issue on another website that I maintain. However, on that site I use a completely different template. There may be some extensions in common, but for the most part they are not very similar. I also tried the various solutions suggested here on that site, again to no avail.
There are two things in common that I am wondering about. One is that they are both on the same hosts, GreenGeeks. All the minimum requirements are met on the host, so that is not the issue, but I still wonder if there is something about the host that would cause the problem. If there is any information on the host that I can send you please let me know.
The other thing in common was that I did have an earlier version of Kunena installed on both. I can't remember if I had uninstalled it on both sites, but I do know that when I installed this latest version all the discussion forums from before were still there. So that much was left behind. Is there a way to do a complete uninstall/reinstall that might fix the issue.
Thanks!
11 years 3 weeks ago - 11 years 3 weeks ago #169754 by mythus
Replied by mythus on topic Preview does not work
Some update information:
I was having trouble with Kunena Login Module - it kept complaining of outdated or whatever info in the fields. Sad. I really liked that log-in module and I hope ya'll get around to releasing one for kunena 4.
Anyway, the point was, I decided to remove it and see if that solved the preview problem. It did not. I decided to uninstall any kunena thing that was version 3, refreshed cache, did global check in, cleared caches in joomla and firefox... still preview is broken. Yet it works here?
It would be great if we could get the preview to work. It would help with those members of mine that aren't savy with bbcode. But... I can't seem to make it work.
Do ya'll need me to repost the console info?
Last edit: 11 years 3 weeks ago by mythus. Reason: Added screenshot showing no working preview and no console errors.
11 years 3 weeks ago - 11 years 3 weeks ago #169762 by sozzled
Replied by sozzled on topic Preview does not work
mythus wrote: I was having trouble with Kunena Login Module - it kept complaining of outdated or whatever info in the fields. Sad. I really liked that log-in module and I hope ya'll get around to releasing one for kunena 4.
The Kunena Login module is unrelated to the preview problem. For what it's worth, the Kunena Login module has not been properly maintained for several years; some people love it and some people hate it. That's just the way it is. If it works that's good; if it doesn't work then c'est la vie.
mythus wrote: I decided to uninstall any kunena thing that was version 3, refreshed cache, did global check in, cleared caches in joomla and firefox... still preview is broken. Yet it works here?
The message preview problem has very little to do with site caching, browser caching, Kunena templates (e.g. Crypsis vs Blue Eagle as suggested by one of the developers earlier ), versions of Joomla (this website currently uses J! 2.5.28) or whether it is a full moon outside tonight.
The cause of the problem is simple: Javascript. The message preview feature requires AJAX . Once people get their head around this requirement then it's fairly easy to explain what has to be done next.
The Kunena message preview works on some websites and it does not work on other websites. That's a fact (and, by the way, I have never had a problem with the message preview feature on any of my websites where I use Kunena).
There are usually two causes why the message preview feature does not work:
1) The webhost does not support JSON; or
2) You have another extension that interferes with the Javascript function, required by Kunena, to generate the message preview feature.
How do you approach this problem? It all depends, really, on how important it is for you to resolve the problem. For some people it is "absolutely essential" to resolve this problem—as you say, some people aren't savvy with BBcode—ut the unmistakable truth is this issue has been with Kunena for as long as I can remember it (certainly from around the time of K 2.0). The reality is that people want the problem "solved" and they're not prepared to invest their time (or money) into the solution.
I have good news and bad news. The good news is that this problem can be fixed; I mean this problem—that affects everyone in different ways—can be fixed in different ways for different people. The bad news is that it costs a little bit to fix the problem. It takes time to identify the cause of the problem: is it a hosting issue or is it a conflict with another extension used on your website? If you have the time (and you do not want outside help) then, at least, you have identified one of those costs ... time!
It would take me forever to explain everything that people can do to resolve the problem. I do not have "forever"; for me time means money and I do not have an inexhaustible reserve of either. :)
There is professional assistance available to help with these kinds of problems (if people want them solved quickly). If people do not want to pay for external help then they will have to accept that their problems will not be solved quickly. Even with professional help, it can still take hours to work through the problem. There you have it: good news and bad news.
Last edit: 11 years 3 weeks ago by sozzled.
The following user(s) said Thank You: mythus
11 years 3 weeks ago #169767 by mythus
sozzled wrote: The Kunena Login module is unrelated to the preview problem. For what it's worth, the Kunena Login module has not been properly maintained for several years; some people love it and some people hate it. That's just the way it is. If it works that's good; if it doesn't work then c'est la vie.
Aye, it's unrelated, and I understand the situation with the module. I only discussed it showing what I was trying in efforts to solve the problem for my site so that others might benefit from it and those who could offer suggestions on how to fix this would understand better all that I was doing.
I do fall in the camp of liking the module of course, so here's hoping that one day someone with skill to do so will give the module some love. Until then, or if such never occurs, as you say, c'est la vie. My site can and will live without it. :)
sozzled wrote: The cause of the problem is simple: Javascript. The message preview feature requires AJAX. Once people get their head around this requirement then it's fairly easy to explain what has to be done next.
The Kunena message preview words on some websites and it does not work on other websites. That's a fact (and, by the way, I have never had a problem with the message preview feature on any of my websites where I use Kunena).
That is understandable. I'll ignore the appearance of a slight there as I am sure that is simply an effect of written discussion with a little bit of aggravation you must be feeling having to address this issue. I would kindly suggest that telling people to get their heads around something or saying that if people got their heads around something isn't the most effective way of responding to issues and would likely cause people with thinner skin to feel insulted, but eh, it's your choice to respond how you see fit. I am just happy that you - or someone somewhat official - even took the time to respond. It is better than feeling like the problem is being ignored, after all.
But enough of that eh? How about we discuss the meat of that quote there. I truly do want to solve the issue, and I am not expecting hand holding - just some kind direction. Do you know if there are any guides available to help tackle this? Anything that might point me in the right direction of where to look to make sure that I have the appropriate JSON support or to see if another module is affecting things?
In my first post to this thread you will see that I provided the report info to help with this, which lists all installed mods. There aren't many but that doesn't mean that one of them isn't affecting things right? I suppose the best route there would be to disable mods one by one and see what happens?
Being an unmanaged VPS that I have full access to, the JSON thing, if that is the issue, could be resolved. Am I right in thinking that ajax requires JSON? If so then I know my server supports it as the shoutbox is ajax/javascript.
Hmm.. maybe the shoutbox is the culprit... Will check and report in a minute. Before I do so, I want to touch on one more thing...
sozzled wrote: It would take me forever to explain everything that people can do to resolve the problem. I do not have "forever"; for me time means money and I do not have an inexhaustible reserve of either. :)
I can definitely understand that, and I would not want you to waste such time. Just giving me a point in the directions I might look is enough, truly.
Sozzled, I want you to know that I understand and appreciate your frustration, and am grateful you responded. I've read plenty of responses you've given on this forum, and I can see quite well what you've had to deal with. Please, take a break, drink a beer, and relax knowing that not everyone is looking for a fight.
If this problem has been brought up often, and it's not already been done, I'd think that maybe a page in the documents concerning it and possible causes to check out would save you and others lots of time.
Anyway, thanks again for responding. I'll check and see if I can find in some way the conflicting extension, and I'll report back my results.
11 years 3 weeks ago #169769 by 810
Replied by 810 on topic Preview does not work
If the preview isn't working there can be a conflict with;
1) Template, try default joomla template.
2) Plugins, disable all none default joomla/kunena plugins
3) Modules, disable the modules on the kunena pages
4) Bug in browser, try with different browsers
todo's
1) Update all plugins,modules,template updates
2) Check error.log on you hosting panel
11 years 3 weeks ago - 11 years 3 weeks ago #169772 by sozzled
Thank you very much for your reply, mythus.
In truth, I'm not in the least frustrated. I'm concerned that people are not getting they help they require and that people maybe expect too much within the confines of a discussion forum. The truth of the matter is that each person's problem is unique. There's no quick fix. There are only some general guiding principles (some of which are only acquired after spending years understanding how the whole website management "thing" works).
There are commonalities, of course. Sometimes the problem is caused by a certain webhosting provider (there's a fairly simple way to check this) and sometimes the problems are caused by one, two or more of (perhaps) dozens of extra "goodies" that the person who designed the website added. And perhaps, sometimes, the phase of the moon may play a part. :lol:
I have a saying: "nothing is impossible; everything has a cost". In other words, as soon as I put a figure on the cost on fixing the problem, the problem (invariably) is solved. If I have any "frustration" it's that people expect that this problem can be solved at zero cost.
Here are some facts:
1) This problem is not caused by Kunena (even though, in my opinion, this topic is incorrectly categorised in the "reporting defects" category here);
2) This problem is caused by "something" that Kunena needs;
3) This problem seems to affect (perhaps) less than 0.1% of all users of Kunena;
4) It can take anywhere between 1 hour and several days to pinpoint the cause of the problem (depending on the software "soup" that is your website);
5) 99.9% of the (less than 0.1% of) people who have this problem are prepared to pay zero dollars to have it fixed.
So, if I have any "frustration" it is only that I don't know what else I can say that I have not already written many times elsewhere in this forum .
You asked for a general guide to fix the problem. Hmm ... "educated guesswork", trial-and-error, serious commitment, patience ... depends really on whether you want to fix the problem that you now have or whether you're looking for an easy workaround.
