Sticky Problems after upgrading to K6.1.3
3 years 3 months ago #228875 by Gindi
Could it be a problem of the language file with the local settings?
My national language is German, I use the CKEditor and so far I have no problems with K 6.1.3
Gindi
3 years 3 months ago #228876 by Leen
Thank you for your response,
Unfortunately, that doesn't seem to be the case either.
Tried everything including language files etc.
Here in the Netherlands the CKeditor suddenly stopped working.
I've already tested it myself with turning off my virus protection etc
But do I do a clean install joomla and then with
Kunena 6.1.2 2023-07-08 then everything works fine again.
That's why I don't really get it anymore.
And it remains annoying that I can now only respond to this forum with the senl reply button, I can type text there
With kind regards
Leen
3 years 3 months ago #228880 by Gindi
It is strange! After I installed a backup of my Lifesite on my local webserver on Friday and updated Kunena from version 6.1.2 to version 6.1.3 and everything worked fine, on Monday I updated kunena 6.1.2 to Kunena 6.1.3 on my Lifesite. Tests showed that everything works without problems.
Today (Tuesday) I wanted to update the Lifesite backup from Friday in another test version on the local webserver from Kunena 6.1.2 to Kunena 6.1.3.
The update failed.
Warning
This extension does not provide a checksum to validate the integrity of the downloaded file.
Copy file failed
Package update: An error occurred while installing the extension: com_kunena_v6.1.3.zip
Before updating, check if it is compatible with the Joomla installation you are using.
It is strongly recommended to make a backup before the update.
danger
Error while updating package.
Although the update failed, Kunena 6.1.2 displayed the Aurelia template in version 6.1.3.
What changed from yesterday to today??
Gindi
3 years 3 months ago #228881 by rich
Nothing has changed, it's still the same package on our download page.
I have already tried everything, but cannot reproduce any of these errors.
3 years 3 months ago #228884 by Leen
okay i'm a step further i don't know if i can explain it well.
But if I extract from pkg_kunena_v6.1.2_2023-07-08.zip the kunena_media_v6.1.2.zip on my PC and from there the \core\js\
the core\js\ckeditor.js and core\js\ckeditor_config.js
copy to the test site "\testkunenazes\media\kunena\core\js\"
then the editors work fine.
I must honestly say that I have tried the difference in this one
two versions to compare but I don't see that so quickly
but maybe someone with more knowledge of these two files will notice the difference
With kind regards
Leen
3 years 3 months ago #228885 by Leen
in version kunena_media_v6.1.3 this is the last line "CKEDITOR.lang.languages={"nl":1};}()); "
and in the version kunena_media_v6.1.2.zip this is the last line
"CKEDITOR.lang.languages={"en":1};}());"
And I can't really explain this both kunena version come
from the download page of the kunena forum
With kind regards
Leen
