- Thank you received: 188
Sticky Problems after upgrading to K6.1.3
The normal editor gives an empty part here where normal icons are and I can't type anything in the message window either
and therefore no screen shots to show this
Tried with another web browser but that didn't help either
With kind regards
Leen
I can write here with action - reply normally in the editor.
Gindi
The normal editor no longer works
can only respond with quick reply
With kind regards
Leen
it happened after the forum was updated to Version 6.1.13 2023-08-10
Have now set all Forum settings to default and cleared cache
Cookies etc also completely cleared but nothing helps.
Maybe this is from which country are you posting something?
With kind regards
Leen
even though I choose subject and for pictures with
then get this message
Cannot save message: Message body is empty!
With kind regards
Leen
Also downloaded and installed the latest kunena version again
but it remains that the CKeditor does not want to work only with the quick reply button I can reply to a message.
If I use the kunena template setting SCeditor then everything works okay
With kind regards
Leen
