Sticky Problems after upgrading to K6.1.3
3 years 3 months ago - 3 years 3 months ago #228822 by Leen
11-8-2023 BEWARE BUG in kunena 6.1.3!
after update kunena 6.1.3 does not work properly anymore! bug: CKeditor no longer works!
so be careful with updates.
ps
Also on this forum only quick response works.
But I use the SCEditor in the Kunena template and it just works here
that's the only way I can edit this post
maybe my problem is clearer now
With kind regards
Leen
Last edit: 3 years 3 months ago by Leen. Reason: that's the only way I can edit this post
3 years 3 months ago - 3 years 3 months ago #228828 by xillibit
I have found the issue, it's where you reply or post a message with filing in the same time the tab private message but i don't see the issue with CKeditor in message or in private message tab
Last edit: 3 years 3 months ago by xillibit.
3 years 3 months ago #228832 by Leen
maybe I don't understand correctly.
But I can only respond on your forum with a quick answer.
The regular reply section message or private message there I can't type anything and icon bar etc is also missing
With kind regards
Leen
3 years 3 months ago #228833 by Leen
oh sorry
I saw too late that you released the latest r 6.1.3 stable
had already withdrawn
With kind regards
Leen
3 years 3 months ago #228834 by xillibit
The other issue that sometime appears it taht it's pretty slow when submit here on kunena.org it takes long or sometimes goes into timeout, i don't find for now on what is related
3 years 3 months ago #228835 by Leen
yes, saving an answer or message has been slow on the kunena forum for a few days with sometimes a time out, I had noticed that too
With kind regards
Leen
