Question Problems after updating to 5.2
5 years 9 months ago #215547 by SBott
When trying to post a quick answer to a topic, the console displays: GET www.people-abroad.de/forum/topic/ 404 (Not Found)
When trying to create a new topic, the console does not display any error message. Same happens when trying to post a regular (not quick) answer.
I found another 404 error in the console when opening an existing thread: GET www.people-abroad.de/forum/user/listmention.raw/ 404 (Not Found)
The thread does display fine, though.
5 years 9 months ago #215552 by rich
Replied by rich on topic Problems after updating to 5.2
Please check your Kunena menu items. Many errors come from wrong configured Kunena Menu items. I cannot see any logic in the paths.
The menu item "Übersicht" show the path .../forum/index/ but goes to the statistics
The Index is called by this address .../forum/forum
See also here:
5 years 9 months ago #215584 by SBott
I did a complete "trash-burn", i.e. deleted the Kunena menu, and related menu items from the main menu (and then emptied the trashcan). Used the "restore Kunena menu" option. Now the forum can be opened here: www.people-abroad.de/forum
However, the same problems are still there :/ Somehow, this installation is broken it seems...
5 years 9 months ago #215587 by rich
Please disable the jch optimize, then empty the cache and test again whether it's not possible to create a new topic.
5 years 9 months ago #215588 by SBott
I disabled the JCH Optimize plugin, then deleted the cache. The problems are still there, though, with the same behavior.
5 years 9 months ago #215589 by rich
Please, would you create an account for me? An account for the frontend (Registered user) would be enough. You can use the confidential tags for the access data (padlock symbol in the editor), then are this info visible only for you and moderators here.
[confidential][/confidential]
