Question Problems after updating to 5.2
5 years 9 months ago #215413 by SBott
We had not updated the forum in a while, and at some point it didn't work anymore with the current Joomla version (posts were not displayed anymore). So now we updated everything to Kunena 5.2.2. That seemed to have worked, and the posts in the forum are displayed again. However, it is not possible to post answers (redirects to 404 error message) or to create new topics (redirects to "current threads", but new thread does not exist). Also threads now show placeholders even though the "use English if no translation available" option is checked (COM_KUNENA_MESSAGE_REPLIED_NEW and COM_KUNENA_SAMPLEDATA_RANK1). What can we do to repair the forum?
This is the report from the backend:
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 256M | Max file upload: 32M
Joomla default template details : jp-pasta | author: JoomlaPlates | version: 1.0.001 | creationdate: June 2015
Kunena default template details : Crypsis | author: Kunena Team | version: 5.2.2 | creationdate: 2021-01-13
Kunena template params:
Kunena version detailed: Kunena 5.2.2 | 2021-01-13 [ Iris ]
Plugins: Search - Kunena Search 5.1.2
5 years 9 months ago #215415 by rich
Replied by rich on topic Problems after updating to 5.2
Maybe it helps, if you go in the backend to Kunena -> Tools and let recount the statistics.
Have you installed also the language package?
There is a separate solution for the untranslated rank names:  www.kunena.org/forum/k-5-2-support-archi...-profile-info#215056
5 years 9 months ago #215484 by SBott
Hi and thanks for your reply!
I did that, but it did not change anything unfortunately.
I installed the 5.2.2. language package and also edited the rank names - this resolved the issues with the placeholders :)
So what remains is the main problem that it is not possible to post answers or new topics.
5 years 9 months ago #215499 by xillibit
Do-you have tried with Crypsis if you have the same issue when post and reply ?
5 years 9 months ago #215514 by SBott
Hi, this happens with Crypsis, yes.
Under "Templates" I also see Crypsisb3 and Crypsisb4...
5 years 9 months ago #215530 by rich
Open your Browser Console (press F12), maybe you get an error message which is more exact as only 404.
Time to create page: 0.161 seconds
