Solved Page does not reload after sending a post
Did-you have tried to do a recount of categories (into tools from Kunena configuration panel) ?
The upgrade to 2.5.28 was not a clean install, it was done as an upgrade from version 1.6 (don't know the exact version anymore).
I tested your idea with the recount of categeries, but that doesn't changed anything.
What I really wonder is that exactly the same forum with exactly the same articles works with catid 52 (example) and not with catid 12. I did have a deeper look into the categories in the database and there is no other difference beetween the forums, not even a little one, so I'm curious and don't think its an upgrade problem.
I didn't had a deeper look in the code, but somewhere the php-script seems to get stopped, if a forum is below the number 31 (old forums). I didn't found any other information in the database which explains this behaviour.
So I thougth there will be a problem of an no more existing user which is still subscribed in this table and blocks while sending the subscribed mails. So I cleared all not existing users from this table, but that doesn't work. All now subscribed users exists in the joomla user table and the kunena user table.
What now could be the problem? What stops the script, which is sending the post from finishing his job? It works without subscriptions and if I only set my subscription to 1, it stops as soon as I set all subscriptions to 1.
Please help me, I'm next getting mad...
Try to remove your smtp host, this is a different one then your own host. Try with your own host.
What does Kunena when sending a post with the subscription, why does it take so long for some users and for other users its done very short? I am really curious about, because 4 mont before (before tis problem appeared first time) I never had a problem like this... And I didn't changed anything, I not even made an update.
Hope for some ideas...
