Solved Page does not reload after sending a post
11 years 1 month ago #169499 by chris9044
Sorry didn't saw your answer. How can I remove my smtp host? This is the host my provider gave me.
11 years 1 month ago #169501 by 810
you can change it on the joomla configuration.
see: www.siteground.com/kb/how_to_setup_mail_in_joomla/
Thats for smtp.
But the default php mailer will be used normal.
set:
- send mail "Yes"
- Mailer * "php mailer"
- From email "Your email adress"
- From Name "The website name"
- Disable Mass Mail "No"
11 years 1 month ago #169507 by chris9044
Yeaah - I think you found the solution. I changed now to PHP-Mail from a completly different provider and it seems to work. But: Is that not a problem for SPAM - Reasons if I send with PHP.Mail. I think I could get blocklisted because of that, or what do you think?
11 years 1 month ago #169508 by 810
on a hoster you can post 500-1000 mails a day. Ask your hoster about that.
With smtp you have the same limit, so it doesn't change anything for you.
11 years 1 month ago - 11 years 1 month ago #169510 by sozzled
chris9044 wrote: Yeaah - I think you found the solution. I changed now to PHPMail ... and it seems to work.
I'm pleased to read that this was the explanation for why, in your case, the page did not reload after posting a message on your forum. I am sorry that it took 2½ months to resolve this issue .
chris9044 wrote: Is [PHPmail] not a problem for SPAM ... I think I could get blocklisted because of that, or what do you think?
Good question! Possibly something we could discuss in another topic.
To be honest with you, I am not sure. Did you read somewhere that using PHPmail on a Joomla could get you blacklisted?
The most likely cause of getting blacklisted is if your email address becomes compromised and if you do not protect the email source appropriately. I am assuming that you have an email address associated with your domain, correct? If this is the case then you can do a couple of things to protect yourself by creating the appropriate SPF record for the domain. This is a difficult area to discuss on a forum but that's one idea.
As I said, interesting question and a discussion that we could have in the Miscellaneous, off-topic and general Joomla category.
Last edit: 11 years 1 month ago by sozzled.
The following user(s) said Thank You: chris9044
11 years 1 month ago #169524 by chris9044
My provider told me about, that PHP Mailer can cause problems. But anyway, I'm very happy that the problem is solved and thank you and the other Kunena Developer, which name I don't see, for the final idea, which solved the topic. Thanks!
Best regards
Chris
