Solved Installation process loops and won't stop
12 years 5 months ago #155921 by colin99
htaccess: Exists | PHP environment: Max execution time: 120 seconds | Max execution memory: 256M | Max file upload: 128M
Joomla default template details : rt_solarsentinel | author: RocketTheme, LLC | version: 1.1 | creationdate: Unknown
Kunena default template details : Blue Eagle | author: Kunena Team | version: 3.0.3 | creationdate: 2013-10-20
Kunena version detailed: Kunena 3.0.3 | 2013-10-20 [ Bifrost ]
Plugins: None
Modules: Kunena Latest 3.0.1
My current Configuration Report -
12 years 5 months ago - 12 years 5 months ago #155923 by sozzled
A couple of things:
1) It looks like you have some outdated and conflicting Joomla menu items (and these may cause problems, if not certainly in the operation of your forum on the frontend but possibly in relation to the problems you are having in terms of upgrading from K 3.0.3). Tidying up the Joomla menu may help.
2) You are using an old, outdated version of Joomla. Updating to J! 2.5.20 may help to overcome problems with "standard" Joomla operations like upgrading Joomla extensions.
3) Your versions of PHP and MySQL may have some influence on the way that installation processing instructions are performed
4) Which method are you using to upgrade from K 3.0.3? Please refer to the K 3.0 Upgrade Guide and describe which of the methods you have been using without success.
Certainly, if there are dozens (or hundreds) of people going through the same turmoil as you, this would be a matter of the utmost concern. We would like to hear from other members of the community who have these kinds of problems. Experiences that are shared are how we all can benefit. So, for all those other people who are having this problem, let's hear from you, too! :)
Last edit: 12 years 5 months ago by sozzled.
12 years 5 months ago - 12 years 5 months ago #155924 by colin99
Thank you for the quick reply --
I did a file restore to a slightly earlier version because of today's issue.
I will get the site as up to date as possible -- I usually run the most up to date
version of Joomla within 7 days of any update (for the shake down...)
And I will examine those other suggestions.
"Outdated and conflicting Joomla menu items..." I am not entirely clear on what that means but I will soon find out.
Many thanks!
Last edit: 12 years 5 months ago by colin99.
12 years 5 months ago #155926 by colin99
Plugins: None
After menu clean up -- I see what you mean.
12 years 5 months ago - 12 years 5 months ago #155927 by sozzled
colin99 wrote: "Outdated and conflicting Joomla menu items..." I am not entirely clear on what that means ...
Look at your configuration report (under "Kunena menu details") and compare with Kunena Menu issues .
You did not explain which upgrade method you were using:
  • "Autoupdate"
  • Upload package
  • Install from directory
  • Install from URL
Which one are you using that is giving you problems?
Have you (at any time) attempted the "auto update" approach and did that method fail? That is a really important question.
12 years 5 months ago #155928 by colin99
I have done AUTO-UPDATE
and then Package Upload.
Both fail -- I can upload any screen grabs that might help us.
Time to create page: 0.162 seconds
