Solved Installation process loops and won't stop
12 years 11 months ago #150232 by iamalive
Hi
Just updated to the latest Version but although everything claims to be OK (and the front end works fine) everytime I try to go to the Dashboard or any other part of Kuena, it restarts the installation process (see image attached).
I've tried reinstalling (with or without Akeeba) but no luck.
Any ideas?
Regards
David
David Jakob
Websites4U.ch
Längmattstrasse 31
CH-4632 Trimbach
12 years 11 months ago - 12 years 11 months ago #150260 by Mortti
This is weird for me, can you please look your server log file what it say about it?
www.kunena.org/forum/77-general-talk-abo...bsites-eg-wamp-xampp
Last edit: 12 years 11 months ago by Mortti.
12 years 11 months ago #150265 by iamalive
Hi
Sadly, the paranoid owner hasn't given me access to the server's control panel.
I was wondering, if I uninstall Kuena, do I loose all the data in the tables? If not, I can try to uninstall the component and reinstall it, but I don't want to loose the data.
Regards
David
David Jakob
Websites4U.ch
Längmattstrasse 31
CH-4632 Trimbach
12 years 7 months ago #154350 by colin99
Same here --
Endless installation loop --
Thankfully on my non-production install (same server...)
Any thoughts or solutions?
12 years 7 months ago #154351 by colin99
Spoke too soon --
I think it was a caching issue.
Turned the caching OFF, cleared the CACHE and the
installer went through normally...
After around 7 attempts.
That is all. :laugh:
12 years 7 months ago #154354 by iamalive
Hi
Clearing the Cache didn't work for me.
What I finally did was go to administrator/com_kunena and delete the install folder then reinstall the component and everything worked fine.
David Jakob
Websites4U.ch
Längmattstrasse 31
CH-4632 Trimbach
