Please Read This First:
Do not use this category for:
Question My cripsis template in Kunena 5.0.1 looks wrong
9 years 11 months ago #181034 by 810
When you have enabled "Load bootstrap" then it should load the files from joomla, I can't see the files loaded on your site.
Please try also clean cache.
Backend - system - clean cache
9 years 11 months ago #181144 by stromboli
Hi ,
I also noted no "Load bootstrap " is on the Basic settings tab:
prntscr.com/d0gfu3
9 years 11 months ago #181148 by rich
stromboli wrote: Hi ,
prntscr.com/d0gfu3
Your image shows the setting options from Crypsis Version 4.0. This version has no load bootstrap option. Please install Kunena 5.0 again.
9 years 10 months ago #181840 by nemmar
I am having the same problems with the Kunena template after upgrading from the prior version. I also use Joostrap templates on some of my sites.
Does anyone have a solution to fix the "new" Kunena templates Crypsis and Crypsis3? The old Blue Eagle template was fine. It seems like many people are having problems with the Crypsis and Crypsis3 templates.
I posted in the other forum category but got no reply with a solution to fix the problem: www.kunena.org/forum/general-user-contri...ith-template-crypsis
Thanks.
Time to create page: 0.211 seconds
