Please note: The Kunena project team takes NO responsibility for maintaining nor supporting anything in this category.
Question Updated from K4.1.2 to K5.0.2 and need layout help with template Crypsis.
10 years 1 month ago - 10 years 2 weeks ago #180516 by nemmar
I just updated from K4.1.2 to K5.0.2. I like the old look of the Kunena forum template (I can see other support forum posts about the same thing). But I realize that the Kunena developers will need time to update or create new templates for K5.0.2. I would like some advice on how to fix the look of the K5.0.2 template in the meantime. Here is the URL: www.nemmar.com/forum/announcements
Can someone tell me how to adjust the columns widths and reduce the avatar icon image sizes? The Category/Topic column on the left side of K5.0.2 is very narrow, the avatar image is very large and a wide center column, the last post link and username is very wide on the right side. The old Kunena forum with Blue Eagle was well designed and didn't have these issues. The only choices in K5.0.2 are Crypsis and Crypsisb3
Thanks for any advice.
Here is my report config info:
htaccess: Exists | PHP environment: Max execution time: 480 seconds | Max execution memory: 512M | Max file upload: 24M
Joomla default template details : JoostrapBase-v3-5 | author: Joostrap | version: 3.5 | creationdate: 22 April 2016
Kunena default template details : Crypsisb3 | author: Kunena Team | version: 5.0.2 | creationdate: 2016-10-01
Kunena version detailed: Kunena 5.0.2 | 2016-10-01 [ Conure ]
Plugins: Search - Kunena Search 5.0.1 | Content - Kunena Discuss 5.0.1
Modules: Kunena Latest 5.0.1 | Kunena Stats 5.0.1 | Kunena Login 5.0.1 | Kunena Search 5.0.1
Last edit: 10 years 2 weeks ago by nemmar.
10 years 2 weeks ago #181575 by nemmar
Can anyone give me advice on what is causing the CSS style problems after I upgraded to the latest Kunena forum version?
I'm not a programmer so I only know basic CSS.
Here is a sample URL and you can see the avatar image is much too large and the row extends off screen and outside the template width:
10 years 2 weeks ago #181580 by rich
It's not a css problem. There is a conflict with your mootools-core.js "/media/system/js/mootools-core.js"
10 years 2 weeks ago #181589 by nemmar
rich wrote: It's not a css problem. There is a conflict with your mootools-core.js "/media/system/js/mootools-core.js"
Hi rich,
Thanks for the info. Do you know where I can post to ask for advice on how to adjust the code to fix this problem? I'm not a programmer so I don't know how to edit JS code. Or is there an edit I can make to Kunena to fix this?
Thanks.
10 years 1 week ago - 9 years 10 months ago #181795 by nemmar
Does anyone have advice on where I can get a different Kunena forum template? Even if it's a paid template I'll be happy to switch.
Last edit: 9 years 10 months ago by nemmar.
9 years 11 months ago #182209 by Tomzie
Have you tried this template? www.kunena.org/forum/general-user-contri...blue-eagle-lookalike ?
It is still a work in progress but I am curious if it solves your issue?
Best regards
Time to create page: 0.169 seconds
