Please Read This First:
Do not use this category for:
Question My cripsis template in Kunena 5.0.1 looks wrong
10 years 1 month ago #179290 by stromboli
Hi!
I just installed 5.0.1 and the problem is taht the template looks like this:
prntscr.com/ccbpw4
Anyone knows how to solve it?
best regards,
Carla
10 years 1 month ago #179298 by 810
On the crypsis settings - choose "Load Bootstrap" option, its on the basic settings tab
10 years 1 month ago - 10 years 1 month ago #179299 by stromboli
Load bootstrap is selected
but the error continues
Last edit: 10 years 1 month ago by stromboli.
10 years 1 month ago #179328 by robbrich
sorry to hijack this thread, but I am having the same issue with a new installation of joomla 3.6 and kunena 5.0.1. I searched the forums and saw that if I were to enable the bootstrap option in the template settings that it should work, but nothing I do changes the layout.
the site template is using 'JooSwatch' by joostrap.com
see attachment to see what is happening:
10 years 1 month ago #179330 by robbrich
I did some digging and found the default bootstrap.css from the template was causing issues with this:
table td[class*="col-"], table th[class*="col-"] {
position: static;
float: none;
display: table-cell;
if I removed the 'float:none;' or changed it to 'float:left' then everything worked correctly.
10 years 2 weeks ago #179675 by stromboli
I changed my Joomla bootstrap.css and no change. Did you mean Kunena's bootstrap file?
Time to create page: 0.329 seconds
