Question Can't merge poll topics
I have very limited time to spend! I also deal with bugs from JomSocial and JReviews. Every Joomla component/module has bugs and having 32.000 registered users means that I face all of the bugs every day due to the emails I get. So in order to get replies in all of my questions be patient.
I do not know how to change "raw data" and I might damage my database.
So I ask 2 questions for this topic:
A)Is it possible for you to allow us splitting a topic with an option on which topic to keep the poll? The topic should be only ONE. There is no meaning on having 2 same polls in 2 different topics?
B)Why Iam not able to delete a poll in a topic? This is a very obvious bug that should be fixed first thing!
I understand the point you made and we tried to address that point in #2 and #3 earlier.Kotsolis wrote: My "Chat" forum has 867 topics ...
I might want to use any from these 867 topics and ... there should be a system where I could click "merge topic" and a screen of the subforum would appear, where all topics would have the option "Merge here". That's one of the very basic moderation tools which exist in every forum component.
I sympathise with you that the merge feature is not as well designed as you would, perhaps, have hoped for but it usually works. However, you are quite right that there is a potential problem when you split a topic that has a poll (splitting the first message—the one that "holds" the poll data) and the result is that two topics are created, both of which have polls, and you cannot merge them back again. Yes, that's going to cause a problem.Kotsolis wrote: Also THERE IS bug here because when I click the "Moderate" button in the 1st post of the Poll topic, there is NO option "Split this and all the 5 replies" as it should! What Kunena does is that it splits the 1st post of the topic, creates 2 polls and then I can't merge those topics!!!
I understand what you did and I'm sorry that it caused a problem for you. I am not the person who designed the polling feature and so I do not know why the split/merge function (when polls are involved) doesn't work the way that it should work. As I mentioned earlier in this topic, it is possible—speaking from experience—to fix the problem by changing the raw data.
I agree with you. This is a very important thing that you should be able to do. It is unfortunate that the answer given earlier ( #9 ) did not work for you. Again, as I have written a couple of times in this topic, it is possible to fix the problem by changing the raw data in one of the database tables.Kotsolis wrote: Why I am not able to delete a poll in a topic? This is a very obvious bug that should be fixed first thing!
Again, I agree with you: there is no purpose in having the same poll in two different subjects. I sympathise with you that there is a defect in merging/splitting topics that involve polls. I don't know what plans the developers may have to address this issue, sorry.Kotsolis wrote: Is it possible for you to allow us splitting a topic with an option on which topic to keep the poll? The topic should be only ONE. There is no meaning on having 2 same polls in 2 different topics?
I understand what you're saying. I also hope that you understand that I volunteer my time here at this forum—I am not paid by anyone to offer my help or the benefit of my experience and knowledge. While I respect your views I also hope that you understand the difficulties that we volunteers also have in trying to please everyone.Kotsolis wrote: The fact that I have opened so many topics it doesn't mean that I don't look at them. I have very limited time to spend! I also deal with bugs from JomSocial and JReviews. Every Joomla component/module has bugs and having 32.000 registered users means that I face all of the bugs every day due to the emails I get. So in order to get replies in all of my questions be patient.
But, even though I offer my advice here in a voluntary capacity, I also run a professional consultancy service as well. Other people who contribute to this forum are also in similar positions. All of us have limitations on the amount of time we can spare to help others, too.
It is unfortunate that a simple mistake that you made, involving a topic that had a poll, is causing you such distress. I am genuinely sympathetic to your problem. What would you like me—am unpaid, volunteer, who did not design Kunena—to do for you?
- Thank you received: 2535
I've tested it and can't confirm this problem.there is NO option "Split this and all the 5 replies"
Why you use the split function if you want merge the complete topic? "First message and all xx messages posted after it" is the complete topic. Use the Moderate Topic button."Split this and all the 5 replies"
I've this also tested, you have found a bug.What Kunena does is that it splits the 1st post of the topic, creates 2 polls and then I can't merge those topics!!!
github.com/Kunena/Kunena-Forum/issues/2660
You must reset votes first before you can edit/remove the poll.Why I am not able to delete a poll in a topic? This is a very obvious bug that should be fixed first thing!
If you can't confirm the problem then I invite you to send me a PM here so that I can send you my password and check it in Gameworld.gr .rich wrote: I've tested it and can't confirm this problem.
Ok, are you going to fix it in the next version?
Once again, there is NO POLL ICON when I try to remove the poll options!You must reset votes first before you can edit/remove the poll.
So how am I supposed to remove them?
Look at the image:
oi62.tinypic.com/vy4lxy.jpg
For over 2 years there has been no PM facility here at this website.Kotsolis wrote: I invite you to send me a PM here so that I can send you my password and check it in Gameworld.gr.
I do not know if the defect , reported by rich, will be fixed or not.
Did you read my reply to you in msg #14 above?
I can't edit raw data. I have very basic knowledge, not that deep! As does the majority of users in here as well, so obviously you have to provide a fix in 3.0.7. If I knew that I can fix it through raw data and I could fix it, I wouldn't ask for your help!
1) Current problem:
I CAN'T remove the polls.
Look at the image:
I except a reply for this!
2)When topics split the poll should remain ONLY in the original topic!
3)When topics with 2 polls merge there should be merged. Users should be able to keep only 1 of 2 polls.
I except a reply for all 3 points. I would pay for these 3 plus the most important A Priority for me " New topics should be marked as Unread for ever so that we don't lose unread topics " .
I would even donate for those!
