Question Can't merge poll topics
11 years 6 months ago - 11 years 6 months ago #160429 by sozzled
Question 1:
Kotsolis wrote: 1) Current problem: I CAN'T remove the polls.
I understand the problem. I could probably fix this for you because I know a few things about how to edit database tables.
Question 2:
Kotsolis wrote: 2)When topics split the poll should remain ONLY in the original topic!
I agree with you! I cannot tell you if, when or how this problem might be fixed in a later version of Kunena.
Question 3:
Kotsolis wrote: 3)When topics with 2 polls merge there should be merged. Users should be able to keep only 1 of 2 polls.
I have already said before (in message #6 of this topic):
You cannot merge topics that have polls in them. A topic can only have one poll; you cannot run two polls in a single topic. I think this explains why you cannot merge those two topics.
I don't think this is a bug. I think it's just not possible in the current design of Kunena.
The short answer to your "question 3" is that I do not know if, when or how this issue might be "fixed" in a later version of Kunena.
Last edit: 11 years 6 months ago by sozzled.
11 years 6 months ago #160433 by rich
As I already mentioned, this is a bug!
Is the same bug. You can only remove the poll in the first original message. But you must reset votes first.
Warning! If you reset the poll if you have divided a topic. This removed the poll also in the second topic!
I except a reply for all 3 points. I would pay for these 3 plus the most important A Priority for me "New topics should be marked as Unread for ever so that we don't lose unread topics" .
Currently, is the amount of time 1 week (I think). But only if they are not logged in. If they log on and not read, these marking are lost at the next login. It has been fixed for K3.1. However, this fix is unfortunately not backwards compatible.
Also THERE IS bug here because when I click the "Moderate" button in the 1st post of the Poll topic, there is NO option "Split this and all the 5 replies" as it should!
On one, from seven test pages I could to produce the error. This error can occur under certain conditions. But I have still not found why it is so. It seems it is a trouble in the table *_kunena_ topics.
11 years 2 months ago - 10 years 9 months ago #162442 by Kotsolis
Replied by Kotsolis on topic Can't merge Poll topics
Can someone confirm to me which of those 2 issues have been fixed to the latest version?
1)Unable to remove poll from a topic
oi62.tinypic.com/vy4lxy.jpg
2)When topics split the poll should remain in the original topic (or let user choose) so that there are not 2 polls in 2 different topics.
Thank you.
Last edit: 10 years 9 months ago by Kotsolis.
11 years 2 months ago #162449 by 810
1) is fixed
2) not fixed yet
10 years 9 months ago #167896 by Kotsolis
In version 4.0.3 you have fixed all the bugs except from one.
When I split some posts from a Poll topic, the posts that are split will take the topic.
That is totally wrong! When I split those posts, I want to move them to another topic. The old topic should remain as it is. This happens to all Forum components as well.
For example in this screenshot, I've split 6 posts and it took the poll with them.
Can you please fix it in the next version? I always have to mysql edit.
10 years 9 months ago #168018 by xillibit
I have looked if i had already fixed something similar by it was an another issue, i will add it to issues github list to remember to fix it.
Time to create page: 0.228 seconds
