Important Cannot fully edit forum profiles (avatar etc)
12 years 4 months ago #157945 by MaydayJoey
Thank you! That worked!
rich wrote: You are using gravatar. You can use either gravatars, or avatars. But not both together.
Go in backend to "Kunena > Plugin Manager" and disable the plugin "Kunena - Gravatar Integration".
You can also disable the following plugins. You have not installed these extensions.
Kunena - AlphaUserPoints Integration
Kunena - JomSocial Integration
Kunena - Community Builder Integration
Kunena - UddeIM Integration
12 years 4 months ago - 12 years 4 months ago #157948 by sozzled
MaydayJoey wrote: Originally I didn't try to use the default template, when I changed it to a j! 3.0 compatible template everything worked except for the table that would allow you to edit your profile. You click on the "edit" button and it would switch but nothing would show up, the area where the table would be is blank.
I think I understand the symptoms better now. I'm guessing that you were getting the symptoms as described in one of the following topics:
where people were using Joomla templates loaded with Javascript that was incompatible with Mootools . Would that be what happened in your case, perhaps?
Last edit: 12 years 4 months ago by sozzled.
12 years 4 months ago #157949 by sozzled
MaydayJoey wrote: So the only issue I have to fix now is being able to properly load templates.
I'm not sure that I understand what this is about but is sounds like it's a different problem. Perhaps it would be a good idea to start a new topic about that problem. ;)
