Important Cannot fully edit forum profiles (avatar etc)
12 years 4 months ago #157926 by MaydayJoey
Date first setup (new install) = 7/24/14
Joomla 3.3.3
Kunena 3.0.5
no other add-ons
Brand new installation (infact, same issue one two different hosts: ipage and hostgater)
Current host: Hostgator
PHP.ini = set factory = meet minimum requirements
mootools enabler = ENABLED
Template = protostar - default
From Joomla:
OS Linux g
PHP 5.4.29
MySQLi 5.5.37-35.1
Time 10:46
Caching Enabled
GZip Disabled
So, I see a bunch of older threads about this issue, but really some pretty generic solutions. I'm not a coder so I can't poke around and see what is wrong, but I have done enough coding to change things if you tell me what needs to be changed.
You can change things like your name, passwords, email etc. But you cannot add FB/social site information or change your avatar, there is simply no option for it.
I really need help with this, I've read the FAQ and checked things like the PHP setup, mootools, etc and do not see an issue this is also from a clean install.... three times.
P.S. as a side note:
I've had other issues with templates not loading correctly and using other templates yields the entire profile editing useless.
12 years 4 months ago - 12 years 4 months ago #157927 by MaydayJoey
you might need this:
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 256M | Max file upload: 64M
Joomla default template details : protostar | author: Kyle Ledbetter | version: 1.0 | creationdate: Unknown
Plugins: None
Last edit: 12 years 4 months ago by MaydayJoey.
12 years 4 months ago #157937 by rich
You are using gravatar. You can use either gravatars, or avatars. But not both together.
Go in backend to "Kunena > Plugin Manager" and disable the plugin "Kunena - Gravatar Integration".
You can also disable the following plugins. You have not installed these extensions.
Kunena - AlphaUserPoints Integration
Kunena - JomSocial Integration
Kunena - Community Builder Integration
Kunena - UddeIM Integration
12 years 4 months ago - 12 years 4 months ago #157939 by sozzled
rich is correct. This issue is discussed in the topic Users are unable to change or upload avatar images (Gravatar plugin is enabled) .
This topic is not about problems that people have during the installation of Kunena; this is one of those problems that often come up afterwards. I think this topic should be moved to the K 3.0 General Questions category; perhaps one of the moderators might do that for us. :)
Last edit: 12 years 4 months ago by sozzled.
12 years 4 months ago - 12 years 4 months ago #157940 by sozzled
MaydayJoey wrote: I've had other issues with templates not loading correctly and using other templates yields the entire profile editing useless.
I'm not quite sure I follow. Am I right in understanding that using certain kinds of Joomla templates prevents you from being able to click the profile Edit link? :dry:
Or is the problem something entirely different? :unsure:
12 years 4 months ago #157944 by MaydayJoey
ok to explain:
- Originally I didn't try to use the default template, when I changed it to a j! 3.0 compatible template everything worked except for the table that would allow you to edit your profile. You click on the "edit" button and it would switch but nothing would show up, the area where the table would be is blank.
- If I switch to one of the stock templates it's fine, which the exception to the avatar. but I do have another problem, if I load an advanced template with custom modules when set to default only loads the features article, background and logo. I see reading through forums that there might be a script error and a setting wrong somewhere. Note that SOME templates load ok but present the issue with editing forum profile.
ALSO:
- turning off the gavater setting fixed the issue with the avatar.
So the only issue I have to fix now is being able to properly load templates.
Time to create page: 0.156 seconds
