Merged K 3.0 buttons display constant names
13 years 2 weeks ago #148149 by sozzled
iaendo wrote: Turns out the solution involved installing Kunena from URL instead of from a downloaded file. Doing so completely resolved every issue I had.
Thus is, in fact, the procedure recommended in the K 3.0 Installatin Guide .
The reason that this is the recommended method is not that the other methods do not work; it's because some webhosting services do not give their users enough resources to allow sufficient time or memory for the installation process to work properly in every case. The K 3.0 installation package is big; the developers have done everything possible to compact the installation package into the smallest possible size - below 2 Mb in total - because some hosted environments have "difficulty" in working with the kind of processing that's involved. Over the past four years we must have dealt with hundreds of cases where people have tried all assortments of ways to install software on their websites and, in the end, we've tried to come up with a one-size-fits-all solution. No doubt there will even be exceptions to this solution but, nonetheless, it seems to be the most practical one ... or at least the one that causes the least trouble.
When in doubt, read the installation/guide; use the recommended approach; keep things simple; start with the basics.
We recommend that people use the "Upgrade from URL" method to install or upgrade Kunena.
I think this now resolves this matter..
12 years 11 months ago #149499 by aklisiewicz
After upgrading to the latest version
my buttons (which are actually on TABS) have changed and show up srange and ugly text
i.e. COM_KUNENA_BUTTON_TOPIC_REPLY
it looks terrible and most new users will think this might be a virus etc.
I'm using minimally modified template. The only changes I made to the template were colors, but I tried to switch back to the default template and no success.
Any ideas on how to fix it ?
Arthur
12 years 11 months ago #149500 by 9themestore
I think you should update some changes of the new version to your current template. I can help you re-check it, if you send me the your site information via email ([email protected]).
12 years 11 months ago #149515 by sozzled
*** Topics merged ***
aklisiewicz: I think you will probably find the answer here in this topic.
12 years 9 months ago - 12 years 9 months ago #151093 by rooster790
[strike]Hello, hoping someone can help with this. I've recently upgraded Kunena to v3.0.3, everything has gone fine except that now once I go into a category or topic the button labels are showing things like:
COM_KUNENA_BUTTON_TOPIC_SUBSCRIBE
and so on..
I've tried switching templates but that didn't seem to help, any ideas?
Thanks[/strike]
Very Sorry - search is a wonderful thing, found a thread covering this issue.
Last edit: 12 years 9 months ago by rooster790.
12 years 9 months ago #151097 by sozzled
For everyone else, this is the topic that rooster790 was referring to.
Time to create page: 0.305 seconds
