Merged K 3.0 buttons display constant names
13 years 3 weeks ago #147837 by Jiminimonka
Where are the forums on your site? After getting past the warning that say your website is untrusted and well dodgy and don't go near it, I come to a website that has no FORUM menu among the other menus.
I suggest you work out why the internet thinks your website is a security risk to browsers as well.
Please read the FAQ.
Only one question per topic.
13 years 3 weeks ago #147844 by paurray
thanks for the info.
I have no idea why this is happening. I will try to investigate!
For me http always worked and https never worked.
Maybe you clicked on a https Link?
With respect to the forum I turned of the page as it was not working.
I went into the back end with a view to turning every thing back on.
The first thing I did was went to Components/Kunena. I just wanted to familarise myself with the Component before turning it back on.
And I got the following error!
See screen shot "KunenaWeirdness01"
Then I decided to uninstall again and got this:
JFTP: :mkdir: Bad response
JFTP: :chmod: Bad response
JFTP: :write: Bad response
Uninstalling plugin was successful.
There are no extensions installed matching your query
And decided to install again...
This time version 3.0.2
But with the same result
I can not figure out how to PM you!
Can you please write to paul(at)paurray.de
Maybe you have some ideas.
best
Paul
13 years 2 weeks ago #147969 by iaendo
I just recently installed the latest Kunena (3.0.2) on a Joomla 2.5.14 site using the latest Community Builder (v1.9). Installation went without a hitch. No errors reported.
I, too, am having the previously reported issue regarding the COM strings instead of the proper buttons. This is occurring in several places: 1) during backend menu item creation 2) the backend menu under the component admin, and 3) front end category navigation.
Please see the attached images.
All other components are working perfectly. This is a problem only with Kunena.
I only have one language file (default English). No templates have been installed.
i have not attempted any configuration or integration with Community Builder. I thought it would be better to resolve this issue first.
Attached is the config log.
If there is any known solution, I would be very grateful to see it. Thanks,
Jon
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 10M
Joomla default template details : coolness | author: jh! design | version: 1.3 | creationdate: Unknown
Kunena default template details : Blue Eagle 2.0 | author: Kunena Team | version: 3.0.2 | creationdate: 2013-08-18
Third-party components: CommunityBuilder 1.9 | UddeIM 2.6
Plugins: None
13 years 2 weeks ago - 13 years 2 weeks ago #147976 by base
I just upgraded from Kunena 2 to 3 and now have code instead of "important" and "solved" images - see attached.
I also now see other code instead of what I ought to be seeing
what do I need to do to get this working properly?
thanks
Last edit: 13 years 2 weeks ago by base.
13 years 2 weeks ago #148117 by iaendo
I'm not sure if I have shared the solution to my problem on this forum, so I thought I would on this thread just in case.
Turns out the solution involved installing Kunena from URL instead of from a downloaded file. Doing so completely resolved every issue I had.
I suppose the installations from file were corrupted or prevented due to a file size max being exceeded... not sure. All I know now is the buttons are all working and displaying properly after the URL install.
13 years 2 weeks ago - 12 years 11 months ago #148118 by 9themestore
Hi base,
Are you using the template of the JoomForest club? So I think, you can request support from the JoomForest club.
Regards
Last edit: 12 years 11 months ago by 9themestore.
Time to create page: 0.268 seconds
