Merged K 3.0 buttons display constant names
But if there are extra language files from the older releases, they prevent the new translations from being loaded. I would enable Joomla debug mode for languages and make a check on which files have been loaded by the system.
In case of Kunena, all the English language files that are loaded should come from the component directory (see sozzleds message), not from the main language directories. So you should have something like this in the debug:
**Language Files Loaded**
**Not loaded** : JROOT/language/en-GB/en-GB.com_kunena.ini
**Loaded** : JROOT/components/com_kunena/language/en-GB/en-GB.com_kunena.ini
If the files get loaded from the wrong location, it could explain why the strings aren't translated.
I am new to this forum as I installed your software yesterday.
I seem to be having the same problem!
I am on Joomla 2.5.11
I have a clean install of 3.0.1 which you can only get to as of now if you login to the Site!
Would appreciate some help as everything else seems to be working fine.
I see that there is some kind of issues with language files.
Inside the com Kunena folder there are what look like 50 language files!
www.finalbug.net
best
Paul
It may be a good idea to read I have the same problem ... because there is a very good chance that your problem is very different. I suggest that you begin by reading the helpful advice printed at the top of this page so that we may know more about why, in your case, the symbolic names are not translated into whatever language you are using on your site.paurray wrote: I seem to be having the same problem!
I upgrade to the last version ( 3.0.1 ) the last week and I found some issue:
1. Some language const are missing for English, The forum works moderated and some of the translation are missing.
example :
COM_KUNENA_SHOWCAT_PENDING
COM_KUNENA_STAT_USERLIST
COM_KUNENA_GEN_MARK_ALL_FORUMS_READ
[strike]2. A few times when I try to approve some threads the forum isn't allow to see the thread, they always show me a list of the threads but the thread that I am trying to answer I can't access, I thinks this can be related with the forum links but I am not sure. This also happened a few times with the Kunena 2x[/strike]
I have the follow configuration :
sh404SEF ( I am using the workaround to allow work with kunena 3.0.1)
Joomla 2.5.11
Kunena 3.0.1
Regards,
Peter
To all those people who have written about untranslated symbolic constants, please read the advice written earlier in this topic from Matias. It would also assist us, when posting messages in this category, to read Rules for posting in K 3.0 Support category . Thank you.
