Solved K 3.0 SEO Meta Description Generators
www.religiousverse.com
Site Summary
Report Details Site Totals Page Averages
Status: Complete
Date: Jul 10, 2013
Pages checked: 500
Duplicate content: 56%
Internal broken links: 0
Redirections 41
Words: 890
Internal links: 44.0
- Kubik-Rubik
- Moderator
- Thank you received: 18
I had the same problem and since I use Kunena on a website with two languages, the result was even worse.
My suggestion for the description function is
- limit number of chars to 140 (or more if you don't use the global description)
- add the language tag
- add global description (optional)
After I have changed the code, everything is fine in Google's Webmaster Tools (HTML suggestion - duplicate description) and the output in Google is better.
Regards
Kubik-Rubik Joomla! Extensions
kubik-rubik.de
- Jiminimonka
- Elite Member
- YBAS!
Kubik-Rubik wrote: Hi!
Code:public function setDescription($description) { if(!$this->state->get('embedded')) { if(mb_strlen($description) > 140) { $description = mb_substr($description, 0, 140).'...'; } $lang = JFactory::getLanguage(); $meta_description = $description.' - '.$lang->getName().' - '.$this->document->get('description'); $this->document->setMetadata('description', $meta_description); } }
Regards
Which file and where were these changes made in?
*Edit: found it, nevermind.
ChaosHead wrote: And again all threads with nofollow attribute?
I call this anti-SEO.
I found a way to resolve this without having to hack the Kunena files each time Kunena updates. I posted what I had done with a component here: Kunena 3 - Replace all "nofollow" attributes
