Solved K 3.0 SEO Meta Description Generators
In 2.0 these changes were made to the /administrator/components/com_kunena/libraries/view.php
Now, that everything is different I am asking for help in finding the code that lists the generation of meta descriptions. The changes in code in 2.0.xx were:
To:
And this screenshot is the problem I am seeing in Google, the global meta descriptions are first and by time the listing is shown the topic descriptions are not visible, after the above changes made in 2.0 the problem went away, and the descriptions were generated correctly. Your help would be appreciated in finding the right files and making the right changes!
Point taken on descriptions. I'll probably going to take a look on those now that we're finalizing the new template. If I forget to do that -- will you remind me later?
Matias wrote: File is the same, but it has just moved to JROOT/libraries/kunena
Hi Matias,
Were these changes implemented in Kunena 3.0? Doesn't appear to be so. Also, I'd like to remove the Topic: from each of the titles being listed in SERPs. Can anyone help me?
Hello,ChaosHead wrote: And again all threads with nofollow attribute?
I call this anti-SEO.
Yes i know, i wanted to remove all this nofollow, if you have some arguments you can add them there : github.com/Kunena/Kunena-Forum/pull/1447
I have just found this site www.siteliner.com which can check if your content is duplicate, i'am not able to run this test on kunena.org
Hi Matias,
I will do it now else it will be forgotten, thanks for remind
P.S. : done look here github.com/Kunena/Kunena-Forum/pull/1834
Site Summary
Report Details
Site Totals
Page Averages
Status:
Complete
Date:
Jul 7, 2013
Pages checked:
500
Duplicate content:
54%
Internal broken links:
1203 (23 pages)
Redirections
30
Size:
25 Kb
Words:
591
Internal links:
33.2
