Solved K 3.0 SEO Meta Description Generators
12 years 11 months ago #149939 by ssh
This is an old article showing how to fix the meta description issue:
ayudajoomla.com/joomla/joomla-seo/655-me...l-seo-en-kunena.html
12 years 11 months ago #149940 by ssh
The new changes to the meta description generator only applies for posts, not for the replies, and all the replies are published using the same meta description as the original post.
any idea?
Thanks in advance,
12 years 11 months ago - 12 years 11 months ago #149984 by ChaosHead
Shimei wrote:
ChaosHead wrote: And again all threads with nofollow attribute?
I call this anti-SEO.
I found a way to resolve this without having to hack the Kunena files each time Kunena updates. I posted what I had done with a component here: Kunena 3 - Replace all "nofollow" attributes
Thank you. But while I see that the years pass, but Kunena team can not fix these minor problems.
Using nofollow on links enables Googlebot to crawl other pages you'd prefer to see in Google's index.
Matt Cutts. support.google.com/webmasters/answer/96569?hl=en
Already waiting, as Sozzled asks my configuration report and write a post in which will be a lot of words, but it will not solve the problem.
Last edit: 12 years 11 months ago by ChaosHead.
12 years 11 months ago #150014 by Matias
There's just not enough free time to fix everything, so I need to prioritize my tasks. :(
The pull request is still in there and in consideration. I've also removed a few nofollows (which BTW, according to Google do not prevent it from visiting the URLs).
The issue on removing nofollows is that we have many different variations of the same URLs and only one of those is canonical -- eg. should be follow. If we just remove nofollow, large forums will not get (again) updated by Google and load on the site increases a lot.
12 years 10 months ago - 12 years 10 months ago #150066 by ChaosHead
No need to remove "nofollow" from all links in Kunena. I ask to remove this attribute only from links to topics.
Example (nofollow links crossed):
Google`s search robot should easily and without restriction index all topics on any Kunena forum. Believe me, I removed nofollow on my forum. After 3 weeks, the number of visitors from Google increased by 30%.
Last edit: 12 years 10 months ago by ChaosHead.
The following user(s) said Thank You: Kubik-Rubik
12 years 10 months ago #150069 by Kubik-Rubik
ChaosHead wrote: Example (nofollow links crossed):
:blink:
You are right, I didn't notice it. This is very bad and needs to be fixed immediately!
Kubik-Rubik Joomla! Extensions
kubik-rubik.de
Time to create page: 0.230 seconds
