Solved K 3.0 SEO Meta Description Generators
13 years 4 months ago #144039 by Shimei
In K 2.xx there was an issue with how Kunena generated Meta descriptions, or at least there was an issue how Google listed Kunena topics in SERPs.
In 2.0 these changes were made to the /administrator/components/com_kunena/libraries/view.php
Now, that everything is different I am asking for help in finding the code that lists the generation of meta descriptions. The changes in code in 2.0.xx were:
From: $this->document->setMetadata ( 'description', $this->document->get ( 'description' ) . '. ' . $description );
To:
$this->document->setMetadata ( 'description', $description );
And this screenshot is the problem I am seeing in Google, the global meta descriptions are first and by time the listing is shown the topic descriptions are not visible, after the above changes made in 2.0 the problem went away, and the descriptions were generated correctly. Your help would be appreciated in finding the right files and making the right changes!
13 years 4 months ago #144049 by Matias
File is the same, but it has just moved to JROOT/libraries/kunena
Point taken on descriptions. I'll probably going to take a look on those now that we're finalizing the new template. If I forget to do that -- will you remind me later? :)
The following user(s) said Thank You: Shimei
13 years 4 months ago - 13 years 4 months ago #144051 by ChaosHead
And again all threads with nofollow attribute?
I call this anti-SEO.
Last edit: 13 years 4 months ago by ChaosHead.
13 years 2 months ago #146059 by Shimei
Matias wrote: File is the same, but it has just moved to JROOT/libraries/kunena
Hi Matias,
Were these changes implemented in Kunena 3.0? Doesn't appear to be so. Also, I'd like to remove the Topic: from each of the titles being listed in SERPs. Can anyone help me?
13 years 2 months ago - 13 years 2 months ago #146067 by xillibit
ChaosHead wrote: And again all threads with nofollow attribute?
Yes i know, i wanted to remove all this nofollow, if you have some arguments you can add them there : github.com/Kunena/Kunena-Forum/pull/1447
I have just found this site www.siteliner.com which can check if your content is duplicate, i'am not able to run this test on kunena.org
Hi Matias,
I will do it now else it will be forgotten, thanks for remind
P.S. : done look here github.com/Kunena/Kunena-Forum/pull/1834
Last edit: 13 years 2 months ago by xillibit.
13 years 2 months ago #146078 by 810
www.kunena.org
Site Summary
Report Details
Site Totals
Page Averages
Status:
Complete
Date:
Jul 7, 2013
Pages checked:
500
Duplicate content:
54%
Internal broken links:
1203 (23 pages)
Redirections
30
Size:
25 Kb
Words:
591
Internal links:
33.2
Time to create page: 0.249 seconds
