Important Kunena 1.5 to 1.6 Language Conversion Tool
16 years 3 months ago #52688 by xillibit
rinuccio sp wrote: 1.But this I can create this structure in any folder?
2.When the converter tools finished to convert, move the language files in their folders... correct?
3.Every time the version is updated I relaunch the tool to get new items to be converted in my language file? or add them manually?
1°) In the same folder where you are put the script kunena15to16-langconvert.php, on the directory fo your server in wamp ...
2°) yes
3°)The script just convert things, so you need to add manually the news strings added in K1.6
Baze wrote: I've used the conversion tool to create Macedonian language file from my 1.5.12 translation, everything went smooth so in the new file "mk-MK.com_kunena.ini" i assume i should uncomment (remove the ; before the new strings) the new translation lines and that's all right?
I don't know why the string are commented :huh:
16 years 3 months ago #52689 by Baze
This is the beginning of mk-MK.com_kunena in the site folder
; $Id: $ ; License GNU General Public License version 2 or later; see LICENSE.txt, see LICENSE.php ; Note : All ini files need to be saved as UTF-8 - No BOM ; Using new string format for Joomla 1.6.x ; Translator comments come into here! ;COM_KUNENA_POLL_STATS_NAME="Poll" ;COM_KUNENA_ONLINE="NOW ONLINE" ;COM_KUNENA_OFFLINE="OFFLINE"...
further down it continues with:
COM_KUNENA_ALL_DISCUSSIONS="Ново на форумот" COM_KUNENA_ANN_ADD="Додади нов" COM_KUNENA_ANN_ANNOUNCEMENTS="Најави"
Since i plan to migrate to kunena 1.6 beta as soon as it's out i plan to finish the language file before so let me know if i'm doing something wrong with uncomenting.. also i'm not sure what should i do with the first line "; $Id: $" should i uncomment it or it part of the comment before the language strings?
16 years 3 months ago #52722 by fxstein
Only worry about lines that start with ;COM....
the first couple comments are for the file header and svn info - do not change or edit them.
Hope this helps!
The following user(s) said Thank You: Baze
16 years 3 months ago #52741 by Matias
Script generates 3 files into admin (2) and site (1) folders. It's one time conversion; you cannot use this script to update translation later on -- I would like to create another one for that purpose when I have some time.
Your task is to take those 3 files and finish the translation.
; Translator comments come into here! <- here you can put whatever you want to, like your name, site etc..
After that line you will find the translation itself (COM_KUNENA_*). Lines that are commented out are new lines from Kunena 1.6 and they contain English strings. Your primary task is to translate and uncomment all of those new strings.
They are commented out because it makes it easier to find new lines -- if you have highlighting editor, those lines will have different coloring, which makes them very easy to find.
After you have translated all the new lines, I would take English language file and look at all the translations side by side against English (all the translations should be in the same order). You will probably find better way to translate many strings. :)
16 years 3 months ago #52742 by Matias
BTW: If you don't know how to use this tool, please post a message (pointing to the latest translation) and our team will do the conversion for you.
