Important Kunena 1.5 to 1.6 Language Conversion Tool
16 years 2 months ago #61023 by Oceanwatcher
Matias wrote: BTW: If you don't know how to use this tool, please post a message (pointing to the latest translation) and our team will do the conversion for you.
I would love if anyone could convert the files for pt-BR (Brazilian Portuguese) from here:
www.kunena.com/forum/107-translations/49...ation-of-kunena-1511
It would help a lot to get started.
Regards,
Oceanwatcher
16 years 2 months ago #61522 by Matias
There seems to be two Turkish translations. One from Tolga and another from Emre (which is already in K1.6)
16 years 1 month ago #67033 by forfattervaerk
Please help me with the conversion - I tried and failed. I need to convert the language to Danish. Here is the latest translation (1.5.6.).
www.kunena.com/forum/143-translations-pr...-translation-for-156
Let me know what I should do in order for you to help me :)
Thanks!
J.
16 years 1 month ago #67035 by xillibit
Try this one :
16 years 1 month ago #67044 by forfattervaerk
Thank you for the files, xillibit :)
Nothing happens so I must be doing something wrong. This is what I did:
1) I put the da-DK.com.kunena_install in the folder:
/administrator/language/da-DK
2) I put the da-DK.com.kunena (from the admin-folder you gave me) in this folder:
/administrator/components/com_kunena/language/da-DK
3)I put the da-DK.com.kunena (from the site-folder you gave me) in these folders:
/components/com_kunena/lib
/public_html/components/com_kunena/template/default
/public_html/components/com_kunena/template/default_ex
Questions:
1) As you can see I'm not sure where to put the last (site) file. There is no folder called "Language" in my /components/com_kunena-folder.
2) I did not use the converter either because I don't know where to put it or what to do with it??
3) Also, if the last (site) file is supposed to be placed in a template folder, I'm not sure if default_ex is the right one. This is the template I used before the upgrade, but kunena chose Blue Eagle (default) on its own. Therefore I put it in both these folder but nothing happens yet.
I will be so thankful if someone will tell me what I'm doing wrong here :) :)
J.
16 years 1 month ago - 16 years 1 month ago #67048 by xillibit
Look here : docs.kunena.com/index.php/Where_is_the_language_file%3F
In the package that i have provided there isn't a language file for template, if you can improve the translation and translate missing file this can be added into kunena.
Files and location : www.kunena.com/forum/107-translations/52...it=10&start=10#52865
Last edit: 16 years 1 month ago by xillibit.
