Important Kunena 1.6 Multi Language
16 years 4 months ago #51542 by MAW_Trok
we need Italians tranlation!!
16 years 4 months ago - 16 years 4 months ago #51564 by svanschu
Feel free to make a translation, we would be happy to include it in Kunena or the KED :)
To do it alone is a lot of work, but you would help the community build another language file for Kunena.
If you don't know how to do it, we can help you, that you can do it :)
Don't know if an HOWTO translate K 1.6 already exist in our docs don't found one atm
Last edit: 16 years 4 months ago by svanschu.
16 years 4 months ago - 16 years 4 months ago #51575 by MAW_Trok
how can I edit the language file? I can translate for you :)
Last edit: 16 years 4 months ago by MAW_Trok.
16 years 4 months ago #51577 by Cerberus
MAW_Trok wrote: how can I edit the language file? I can translate for you :)
take the two english language files from kunena ( frontend/backend ) and open in your favorite txt editor and translate them :)
16 years 4 months ago #51626 by MAW_Trok
ah ok perfect. very easy.. as older versions! :-D
16 years 4 months ago #51627 by Cerberus
yes just the files are a different format than before if i remember rightly, so remember to save it as same format as original or i wont work. :)
