Important Kunena 1.6 Multi Language
16 years 4 months ago #51649 by MAW_Trok
50% of front translated.... now I am tired.... tomorrow I should complete the front! :-D I hope my contribute will be usefull for all italians member.
16 years 4 months ago #51666 by MAW_Trok
there is a bug on this line of code in fronted COM_KUNENA_EDITOR_HELPLINE_SPOILER
I can't use this this letter àòéù. I write for example é or á but I dont' see the simbols, but wat I wrote in the code. I see "Spoiler é utile per blablabla" why? with other line I don't have problem!
16 years 4 months ago - 16 years 4 months ago #51667 by MAW_Trok
same problem in this line COM_KUNENA_EDITOR_HELPLINE_HELP="Suggerimenti su come utilizzare l´editor bbcode"
As I suppose there is a problem for simbols in editor. If i write the simbol "à" in language, in the forum I see this simbols "?"... if I write this code in the language "à", in the forum i see "à"............. so I can't translate in italian. :-(
Last edit: 16 years 4 months ago by MAW_Trok.
16 years 4 months ago #51678 by Matias
We seem to have the old bug back, probably triggered from language file change. None of those texts can have special characters as they are defined inside JavaScript.
I will try to look into this and fix it before going stable.
16 years 4 months ago #51680 by MAW_Trok
thanks :-D
16 years 4 months ago - 16 years 4 months ago #51692 by Matias
Just to be sure: can you use those letters elsewhere? Sometimes files get saved in ISO-8859-X instead of UTF8..
Also do not use ´ as language file accepts every UTF8 character except " (without escaping it)..
Last edit: 16 years 4 months ago by Matias.
