Use this category:
Question JInstaller: :Install: SQL-Fehler Duplicate entry 'com_kunena.reply-' for key 'PR
yes i checked database. it says there are no errors and it has current state.
Shall I overwride all joomla core files again via ftp? ( with fielzilla for ex.)
- Thank you received: 2545
docs.kunena.org/en/basics/upgrade/upgrade-k6-0
I would go mad. How else can I fix it? Can I not just import tables? Which one exactly?
(By the way everything else works except Kunena)
ps
And what you might try (but I would first do this locally with Wamp or Xampp) is to export all your prefix_kunena from your database to your pc and then save it then remove everything from kunena from the database and then see if you can install kunena. if that works you might remove all kunena from database again and then import the saved kuena.sql
With kind regards
Leen
the xxxxx_ mail_templates only occurs in joomla 4
With kind regards
Leen
