Use this category:
Question JInstaller: :Install: SQL-Fehler Duplicate entry 'com_kunena.reply-' for key 'PR
4 years 1 month ago #225739 by martinsai
Hi Team,
I upgraded from Joomla 3 to J4. I could install several extensions without probs. Just with Kunena it went wrong. In Joomla 3 before upgrade I use V 5.2. and I uninstalled Kunena as described. Now in Joomla 4 I wanted to install V6 but the error "JInstaller: :Install: SQL-Fehler Duplicate entry 'com_kunena.reply-' for key 'PRIMARY'" comes. Server should be ok. What to do?
thnx in advance
4 years 1 month ago - 4 years 1 month ago #225740 by Leen
maybe this helps
"Remove the kunena entries in the table #__mail_templates "
www.kunena.org/forum/k-6-0-support/16466...-duplicate-entry-com
With kind regards
Leen
Last edit: 4 years 1 month ago by Leen.
4 years 1 month ago #225773 by martinsai
4 years 1 month ago #225774 by Leen
if it is not there with filters mail  then it must be something else
might be useful to have a Create and Post Configuration Report
www.kunena.org/docs/en/manual/backend/to...report-configuration
With kind regards
Leen
4 years 1 month ago #225775 by martinsai
nice idea, but in my dashboard > components there is no Link to any Kunena content. I could install the kunena language pack though.
4 years 1 month ago #225809 by rich
It seems that something went wrong during the migration from Joomla 3 to Joomla 4 when the #__mail_templates table is missing. It seems, the missing table trigger the error.
Is the error displayed in the Backend -> System -> Database? If so, try the repair option.
