Use this category:
Question JInstaller: :Install: SQL-Fehler Duplicate entry 'com_kunena.reply-' for key 'PR
4 years 1 month ago #225838 by martinsai
ok, first answer is see attachd image: in extension manger kunena is displayed but not on dashboard >components!!!
4 years 1 month ago - 4 years 1 month ago #225843 by Leen
I miss System - Kunena Forum can it be found at joomla4 plugin manager ?
and is the database okay does Maintenance: Database give no error message?
With kind regards
Leen
Last edit: 4 years 1 month ago by Leen.
4 years 1 month ago #225865 by rich
(By the way everything else works except Kunena)
If the #__mail_templates table is not present, no mails will be sent.
Install Joomla again via Joomla Update. Maybe you are lucky and this table will be created.
4 years 1 month ago #225933 by martinsai
Hi Rich, now all missing data tables (including mail_templates) have been inserted but still cant install kunena. I am going mad. Even deinstalling did not work: see img
4 years 1 month ago #225947 by Leen
in Extensions: Manage
click green V to turn extension off
and select the extensions again with square and click on
uninstall then you should be able to get those 2 away
With kind regards
Leen
4 years 2 weeks ago #226413 by HarryT3
Hi
If you have still this issue, the problem is 3 entries in the table jos_mail_template  (assuming you have the default jos_ prefix)
After a complete uninstall you can, as a workaround, open your database with phpmyadmin and enter the sql statement
delete FROM jos_mail_templates where template_id like 'com_kunena%'
Afterwards you can install Kunena again.
{HT}
