Solved Succecfully installed but NO kunena at components
4 years 3 months ago #224031 by uzbaby
Hello!
I installed joomla 4.1. All worked fine. I installed Admin tools, also successfully.
Then I installed Kunena. As you see it is in the extensions. But I don't see Kunena dashboard.
What is wrong? During installation I got "Package successfully installed" massage  and "Error 404"
And my Joomla dashboard become strange and as you see the words: undefined constant "Kunena\Forum\Libraries\Factory\KPATH_ADMIN"
You can see the images in the attachment.
4 years 3 months ago - 4 years 3 months ago #224032 by uzbaby
I uninstalled Kunena. How can I install it without problems in my Joomla 4?
Last edit: 4 years 3 months ago by uzbaby.
4 years 3 months ago #224034 by Leen
I don't know if your admin tools specially set it up and if that affected kuena.
And how you removed kunena again normally this has to be done via Kunena Forum: Tools
so if you have removed it via joomla management there may be something more happening in the database.
but normal if your hoster have  the right requirements could it just be installed as described here
www.kunena.org/docs/en/basics/installation/installation-k6-0
With kind regards
Leen
4 years 3 months ago - 4 years 3 months ago #224035 by uzbaby
I reinstalled Kunena and now it shows this (screenshot in the attachment  )
4 years 3 months ago #224036 by uzbaby
I reinstalled it via Extensions manager and then due to error in my Joomla Dashboard ("Kunena\Forum\Libraries\Factory\KPATH_ADMIN") I deleted all files of kunena in my Core File Manager.
4 years 3 months ago #224042 by Leen
it looks a bit like this error message
www.kunena.org/forum/installation-issues...-installation#223100
only his solution may not be entirely suitable for your site.
For example, if you have a backup from before you installed kunena I would put it back and try again.
And if you've just started everything do it all over again start with everything (including an empty database)
With kind regards
Leen
