Use this category:
Solved Error in installation
4 years 6 months ago - 4 years 6 months ago #223092 by serge73
Hello
I have trouble in stallation of  pkg_kunena_v6.0.0-RC2_2022-04-07
I have migrated my site from joomla 3 to 4
The first migration was done and kunena was not OK
SO I have uninstall kunena
And now whan I try to install kunena I have the error message
  • Warning
  • JInstaller: :Install: Error SQL Duplicate entry 'com_' for key 'PRIMARY'
  • Extension installation aborted.
  • Package Install: There was an error installing an extension: com_kunena_
Is someone can help me ?
Thank you
Last edit: 4 years 6 months ago by serge73.
4 years 6 months ago - 4 years 6 months ago #223093 by serge73
Replied by serge73 on topic Error in installation
I try to remove all kunena table with phpmyadmin
Nothing change
The error messages are :
danger
Error installing package
4 years 6 months ago #223095 by xillibit
Replied by xillibit on topic Error in installation
It's the same answer that what i had given here : www.kunena.org/forum/76-Official-Announc...-beta-version#223066
4 years 6 months ago - 4 years 6 months ago #223096 by serge73
I had this output after the installation see screencopy
And My joomla seems completly broken see screencopy
And the message
Une erreur est survenue
0 Undefined constant "Kunena\Forum\Libraries\Factory\KPATH_ADMIN"
I need to restore it
How manually completly remove kunena ?
Serge
4 years 6 months ago #223099 by rich
Replied by rich on topic Error in installation
How can someone help you if you don't respond to answers?
If you have alrady removed the Kunena tablles, copy back the kunena tables, then do what xillibit suggested. Afterward try to install Kunena again.
4 years 6 months ago #223100 by serge73
Hello
I try to remove table and files and folder of kunena
But After I had also Problem
I will try again on a test server
But you did reply to my last post
And the message
Thank for your help
Time to create page: 0.160 seconds
