The actual installation procedure takes less than two minutes on most sites. Kunena is a Joomla component and it is installed like any other Joomla extension using the Joomla installer.
This document describes only the additional steps after installing Kunena 6.0. If you are not familiar with the installation procedure, please refer to the Installation document.
It’s important to backup first before doing the installation.
The forum should now be ready and you can test and customize it.
Found errors? Think you can improve this documentation? edit this page
